Thread: P 0452 DTC EVAP Low Sensor Error 2007 GP
Results 1 to 2 of 2
  1. #1 P 0452 DTC EVAP Low Sensor Error 2007 GP
    Feb 2013
    Phoenix,AZ
    Even when I clear the error it comes back. It's indicating a leak somewhere. I tried a new gas cap. That didn't work. It comes on within a minute of clearing the error. What should I look for next? A broken hose or something? Any one get this error before?
  2. #2 Re: P 0452 DTC EVAP Low Sensor Error 2007 GP
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Broken wire or bad pressure sensor. Doesn't have anything to do with a leak.
    Code is set when the FTP sensor voltage is less than .1volts for more than 5seconds.
    Gray/blk is 5volt reference. Pin 53 on pcm F on tank plug.
    Dr green is fuel tank pressure signal pin 26 on pcm G on tank plug.
    Blk is low reference. (ground) pin 8 on pcm H on tank plug
    Tank plug can be accessed under the cover in the trunk. Check for continuity and less than 5ohms from a to b on each wire. I'd put money on the sensor. But checking the wiring isn't too bad.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. GP GXP 2007 tire sensor
    By HarryO45 in forum General Tech Discussion
    Last Post: 08-07-2013, 07:46 PM
  2. EVAP Switch, MAP Sensor Bracket. 97 GTP
    By slydoggy38 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2013, 09:01 PM
  3. P0440 Evap control cel? Just added new fuel level sensor and CAI
    By ST0NGE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2012, 04:31 PM
  4. Amp error?
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 04-23-2010, 07:43 AM
