So what's the deal with those top coolant holes being so damn small..
is that normal?
is that normal?
bump
Nobody..?
If anything you should have deleted this one. The other one had better questions in it. I need some mother****ing answers in here. Has nobody worked on a Grand Prix before?
Maybe because majority of us stick to Felpros. Call the manuf and find out.
http://shop.zzperformance.com/store/...&bw=600&bh=600
look at that they are pretty much the same, 2 min on google
^ there you go. Honestly that's wht they look like Idk exactly why they make them so small but it works out fine.
don't worry about the spray, just make sure the deck on your cylinder head is straight and not marked up.
a freshly shaved head will seal better then a 3 thou warp and some sealent
this is off the cometic web site
http://www.cometic.com/technical.aspx
Why does Cometic recommend MLS gaskets to be installed dry?
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick Viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
zzp doesn't know what they are talkin about sometimes, don't allways believe what a vendor says
Left and right gaskets are different for proper water flow in the block. The difference is the diameter for coolant flow.
Intense and ZZP both use copper spray.
http://intense-racing.com/Merchant2/...FEATURED_ITEMS
I copper spray all HG's. IT's overkill on the Felpro's but hell.. I've yet to have one leak.
