Thread: General Maintenance on a 08 Grand Prix at 50, 000 miles
Results 1 to 7 of 7
  1. #1 General Maintenance on a 08 Grand Prix at 50, 000 miles
    Jackson, Mississippi
    What general maintenance needs to be done on a 08 Grand Prix with only 50, 000 miles??
  2. #2 Re: General Maintenance on a 08 Grand Prix at 50, 000 miles
    SE Level Member Gpmadness08's Avatar
    Sep 2013
    Peoria IL
    Tranny fluid n filter... Fuel filter if accessible but I believe it's in with fuel pump on this yr... I'd also recommend suspension bushing check n replace (sway bar links and control arms)... Also do visual check on plugs n wires (they are rated for 100k but I'd check anyways to find probs)... I'd also test radiator fluid to make sure temp rating is stable
    ~ : Andrea : ~
    2008 GP @>~~\~~~
    Aka Charlotte
  3. #3 Re: General Maintenance on a 08 Grand Prix at 50, 000 miles
    The coolant needs replacing, its five or more years old. It's rated for five by GM.
    Every fluid in the car is likely past it's prime. This includes brake, power steering, coolant, transmission.
  4. #4 Re: General Maintenance on a 08 Grand Prix at 50, 000 miles
    Ok Thanks for the info!
  5. #5 Re: General Maintenance on a 08 Grand Prix at 50, 000 miles
    Thanks!
  6. #6 Re: General Maintenance on a 08 Grand Prix at 50, 000 miles
    As far as the plugs and wires go. Is it best to go back with the original plugs by the manufacturer or would you recommend another brand?
  7. #7 Re: General Maintenance on a 08 Grand Prix at 50, 000 miles
    You can save a bit on wires and get a premium lifetime warranty set.
    On the plugs, AC Delco 41-101. Easiest way to go as that is the factory plug which will be good for another 80K.
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 10-03-2014, 06:25 PM
  2. looking to buy 04-08 grand prix general questions
    By AJB420 in forum Introductions/Noob Questions
    Last Post: 02-06-2013, 10:52 AM
  3. general maintenance ideas
    By DirtDog in forum General Tech Discussion
    Last Post: 10-08-2012, 07:59 PM
  4. 2006 Grand Prix Maintenance Advice (low miles)
    By Maxvla in forum General Grand Prix Discussion
    Last Post: 08-14-2012, 08:19 PM
  5. 99 Grand Prix - general (sorta) questions
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-05-2011, 03:32 PM
