Thread: Anyone try these gauges?
Results 1 to 19 of 19
  1. #1 Anyone try these gauges?
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Found these gauges on EBAY, but they seem kind of cheap to me. Has anyone tryed them? Should i try it out?
    LED Digital Oil Pressure Car Auto Gauge Smoked Len Pod | eBay
  2. #2 Re: Anyone try these gauges?
    Em something as important as oil pressure I will not put my trust into a no name brand. Plus at that price you can easily get gauges from a more respectable brand like autometer, aem etc
    04 Comp G.
  3. #3 Re: Anyone try these gauges?
    Banned
    Jan 2013
    Colorado
    i wouldn't trust it
  4. #4 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    Ok thats what i thought. Trying to look for gauges that wont make me broke.
  5. #5 Anyone try these gauges?
    Quote Originally Posted by Yamahakid88 View Post
    Autometer, aem, prosport are some option.
    04 Comp G.
  6. #6 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    Autometers are like 100$ :/ ouch.. Grocery store money can only buy so much unfortunately
  7. #7 Re: Anyone try these gauges?
    GTP Level Member
    Sep 2011
    Motown
    Go big or go home, if you dont spend the money now for a good set you will be spending it later to get another set. Just my 2cents.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  8. #8 Re: Anyone try these gauges?
    Your not looking hard enough or your looking at digital ones which yea they aren't going to be that cheap.
    http://item.mobileweb.ebay.com/viewi...d=290610062768
    http://item.mobileweb.ebay.com/viewi...d=250826263188
    http://item.mobileweb.ebay.com/viewi...d=141048328944
    Some examples
    04 Comp G.
  9. #9 Re: Anyone try these gauges?
    GTP Level Member
    Sep 2011
    Motown
    All honesty I would spend the money on an oil pressure gauge and get an electrical one. The hose will only last so long on a mechanical one....then you may have oil all over the interior of your car.
  10. #10 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    Ya i have been looking at the digital ones, the analogs will not be back lit correct? Id like to be able to see them at night.
  11. #11 Re: Anyone try these gauges?
    My bad I didn't realize I posted mechanical ones. Definitely get electrical unless you enjoy running a oil line inside the car.
    Autometer digital is going to be out of your range (based on what you posted before)
    Check out prosport they may have something in your range.
    04 Comp G.
  12. #12 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    Ok ill check them out man. Thanks for the help
  13. #13 Re: Anyone try these gauges?
    No problem.
    04 Comp G.
  14. #14 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    Ok i had a chance to look at the prospect gauges and they seem pretty well priced. What gauges would you suggest having on a n/a Gp?
  15. #15 Re: Anyone try these gauges?
    They are known to work well enough if they work.
    There is a chance they won't. As well as a good chance they won't be terribly accurate. By that I mean off by a pound or two. But it really won't matter. It's all about making sure the numbers are within the norm for your setup so you know if something has gone awry.
    To be honest though, for a N/A GP, the only thing you really need is temperature which the stock guage does just fine. Knock doesn't matter, vacuum doesn't matter, oil pressure doesn't matter.
    If it knocks or not, won't make or break your car. Vacuum won't matter because you can still pull decent vacuum with small vacuum leaks. Meaning you should check thoroughly and often regardless of vacuum reading. Oil pressure doesn't matter as when the dummy light comes on, that's when you don't have enough oil pressure. But if that happens, the engine is likely damaged and in need of repair or replacement. If you have an oil pressure guage, there is no way it will help you to save the engine if you have an oil pressure issue. The reason being, the main cause of oil pressure issues is a rod bearing failing. Not the oil pump or some other gasket that can simply be replaced. If it was another engine where there was a common issue with say the pickup tube gasket or the oil pump failing, then yes, oil pressure would be worth investing in. But luckily, those items are a non-issue with the 3800.
  16. #16 Re: Anyone try these gauges?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I have glowshift gauges. Decently priced, many options, changes color, and they work phenomenal.
    Volts, boost, oil pressure in the A-Pillar.
    If you go with them, and get the oil pressure, get the adapter sandwich with it, it makes installation 100x easier. Well worth the extra $25.
  17. #17 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    Will a boost gauge still work with a non supercharged gp?
  18. #18 Re: Anyone try these gauges?
    Banned
    Jan 2013
    Colorado
    it will only read vacuum but yeah.
  19. #19 Re: Anyone try these gauges?
    Jun 2013
    Illinois
    thanks for the advice. I'm kind of regreting not getting a gtp :/ Thinking about getting one and just selling the gt.
  1. Gauges
    By Metalbluegp in forum Visual/Body Modifications
    Last Post: 06-05-2013, 10:31 PM
  2. Gauges
    By 2000supercharged in forum General Grand Prix Discussion
    Last Post: 09-28-2012, 03:56 PM
  3. Gauges?
    By Greenmachine in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2012, 10:11 AM
  4. Gauges Im Doing!!!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 05-05-2010, 12:08 AM
  5. Gauges
    By ssm90GT in forum General Tech Discussion
    Last Post: 10-14-2008, 07:30 PM
