Thread: the old abs tcs light came on
Results 1 to 9 of 9
  1. #1 the old abs tcs light came on
    Jul 2013
    adrian, mi
    these cars are known for it but since it doesnt throw a code i was wondering what fails and causes these lights to come on?
  2. #2 Re: the old abs tcs light came on
    A scan tool that can read ABS codes will tell you weather there is a circut fault or a wheel bearing itself is bad.
  3. #3 Re: the old abs tcs light came on
    Donating Users
    Aug 2013
    Michigan, USA
    keep in mind some of the budget OBD reader like the $50 model at Walmart will only read engine code. You'd need a pricier model that reads everything so head to a mechanic if you don't have one. The one my Dad uses at his auto shop is around $4,000 but it can do everything including adding key fob, relearning, etc.
  4. #4 Re: the old abs tcs light came on
    Jul 2013
    adrian, mi
    Like a tech2?
  5. #5 Re: the old abs tcs light came on
    no like a abs code scanner. make sure it covers your year make and model car, read the reviews.
    but some newer cars some abs codes will come up on a regular code scanner. they did on my friends 04 GM truck.
  6. #6 Re: the old abs tcs light came on
    Max Cook
    Guest
    It can be a wheel bearing going bad, wiring issue (bad grounds somewhere or clipped), bad sensor on wheel bearing, or the EBCM module can be going bad.
  7. #7 Re: the old abs tcs light came on
    unless you find bad wires, or a loose hub, its best to scan it as hubs are pricey to be just tossing parts at a abs problem.
    most shops will charge you up to 75 bucks for the abs scan, or a cheap on line abs scanner can be found for about 50, more or less.
  8. #8 Re: the old abs tcs light came on
    Max Cook
    Guest
    ya im not really saying to toss parts at it but he did directly ask what can cause it so I decided to list it lol.
  9. #9 Re: the old abs tcs light came on
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Yes a tech2 reads abs info.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. driver side parking light and fog light not working
    By shelbyguy04 in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2013, 01:37 AM
  2. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  3. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  4. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
