Thread: Driver door hinge roller stuck
Results 1 to 7 of 7
  1. #1 Driver door hinge roller stuck
    Aug 2013
    GA
    20130821_113903.jpgThe roller at the bottom of the driver's door top hinge is stuck. Is there a fix for this or do i have to get the whole hinge assembly? Thanks,
    Brandon
  2. #2 Re: Driver door hinge roller stuck
    HUDSON
    Mine did that too, it made a horrible noise when the door was opened so I just removed the spring. The door will not hold open by itself now but that does not bother me as mush as the god awful noise it would make when I would open the door. Their is not much room in their to work on it as I tried to turn the roller by hand but just not enough room to get a good grip on it. The proper way to fix I suppose is to replace the door hinge.
  3. #3 Re: Driver door hinge roller stuck
    Feb 2013
    Woodbridge NJ
    When I bought the 2004 GT1 for my son the driver door was making a horrible squeak. Bought some lithium grease spray and it is quiet as a mouse now
    Don
  4. #4 Re: Driver door hinge roller stuck
    the wheel looks like its 1/2 broke off. see if it comes off, maybe its replaceable.
  5. #5 Re: Driver door hinge roller stuck
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Just go to the JY and get a replacement set of hinges off of the passenger side of a 4door, it's literally the same hinges but since the door is lighter and no one ever opens it they usually stay in good shape.
  6. #6 Re: Driver door hinge roller stuck
    Aug 2013
    GA
    Quote Originally Posted by addzradd View Post
    Good deal, I'm going to a junkyard tomorrow anyways, I'll do just that. Thanks!
  7. #7 Re: Driver door hinge roller stuck
    Feb 2010
    Cleveland
    just need a good 13 mm racheting wrench to make it easy.
  1. Replies: 3
    Last Post: 09-09-2013, 10:12 AM
  2. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
  3. door hinge roller wheel
    By dougf in forum 04+ Specifics
    Last Post: 02-24-2011, 09:42 PM
  4. door hinge / pins
    By hourang in forum General Tech Discussion
    Last Post: 12-11-2010, 12:27 PM
  5. UPDATE, pg.2!!! Drivers Door Adjustment? Hinge?
    By Iron Indian in forum General Tech Discussion
    Last Post: 12-30-2008, 12:52 PM
