Thread: Blower motor not working on all speeds.
Results 1 to 11 of 11
  1. #1 Blower motor not working on all speeds.
    GT Level Member gpbastard's Avatar
    Florida
    I have an 01 GP SE w/ manual heat and a/c. about 3-4 years ago i fixed the passenger side water leak that is common with these cars. after that i replaced both the blower motor (OEM) and the blower resistor. no problems since then until the blower motor stopped working recently. Thinking it was the contacts in the ignition switch iput in a bypass relay per Backinblack's ignition mod. that didn't help so now i'm thinking the Blower motor is bad. it doesn't work on any speeds and the #5 speed fuse is good.
    gpbastard
  2. #2 Re: Blower motor not working on all speeds.
    Donating Users Burgundyman's Avatar
    I just replaced mine (i.e. blower motor) today. The blower resistor was fine. I had water seep through the cowl because the weather stripping was dislodged. There was an inch of water at the passenger side.
    I cleaned the firewall lip and applied some RTV to weather strip before re-affixing. I removed the blower motor and discovered that it does not turn freely. I purchased one identical to my GM OEM from Advance Auto Parts ($59.99). The GM OEM motors are made in Canada. I used a multimeter to check voltage to the blower resistor and then to the motor from the resistor. Everything checked so then I knew the motor was shoddy. Given that water was leaking into blower housing, it makes sense that the motor would succumb to failure. Hope this helps. The key is to use a multimeter to check voltage drop across your connections.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  3. #3 Re: Blower motor not working on all speeds.
    Florida
    Quote Originally Posted by Burgundyman View Post
    i have a Mmeter. how do i check for voltage. in other words where do i put the negative probe at? do i put it on a ground?
    gpbastard
  4. #4 Re: Blower motor not working on all speeds.
    First unplug blower resistor. It is a two wire harness. With the system off, take each prong from multimeter and place them onto contact leads in harness. One wire is live and the other is a ground. There should be no voltage drop when the system is completely off. If you turn the fan switch on power should be flowing through the harness. That would be good news. If this is not the case, unplug the three wire harness from the blower resistor and check for power.
    RED- 4 Door Sedan
  5. #5 Re: Blower motor not working on all speeds.
    Florida
    thanks for the info. i'll check it out tomorrow and i'll post with an update. my guess is the resistor or the motor. thanks again.
    gpbastard
  6. #6 Re: Blower motor not working on all speeds.
    No worries. Let me know. The blower resistor is quite pricy for auto climate control but much less expensive for manual climate control systems. Good Luck!
    RED- 4 Door Sedan
  7. #7 Re: Blower motor not working on all speeds.
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    Pull the blower motor out and hook it to a battery if it work you know it's fine try the resistor but I once had the ignition switch be the issue for why my blower didn't work.. Sadly went all winter with no heat but got it fixed in the spring lol
  8. #8 Re: Blower motor not working on all speeds.
    Florida
    Quote Originally Posted by mofford12 View Post
    thanks, i'll be pulling the motor tomorrow and checking that too. i put in a new relay for the ignition switch so that shouldn't be a problem. i still think it's the motor or resistor.
    gpbastard
  9. #9 Re: Blower motor not working on all speeds.
    Florida
    Good news! I got it fixed. It was a bad blower motor resistor. Works good as new again. Thanks again for everyone's help on this.
    gpbastard
  10. #10 Re: Blower motor not working on all speeds.
    That's awesome. My motor ultimately failed from water entering the blower motor housing after I discovered 1+ inch of water on the passenger side.
    RED- 4 Door Sedan
  11. #11 Re: Blower motor not working on all speeds.
    Florida
    common problem. same happened here a couple of times (i fixed it long time ago) it was like an aquarium when it rained. i put in a new resistor when i repalced the motor about 4 years ago so i'm surprised it went out. i didn't see any evidence of water leakage when i tore everything out the other day. also i have 140k on the car so as a precautionary move i put a ignition switch bypass relay in as well. thanks again for the help.
    gpbastard
  1. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  2. 2004 gp replaced blower motor & resistor ? not working
    By poppy in forum General Tech Discussion
    Last Post: 09-06-2012, 04:47 PM
  3. blower speeds
    By time3777 in forum General Grand Prix Discussion
    Last Post: 06-28-2012, 06:00 PM
  4. 99 GT blower motor not working
    By Phrozen99 in forum General Tech Discussion
    Last Post: 09-17-2011, 01:21 PM
  5. Blower motor speeds 1-3 quit working.
    By WhiteGT in forum General Tech Discussion
    Last Post: 11-16-2008, 04:28 PM
