Thread: 2004 GTP Problems ?
Results 1 to 6 of 6
  1. #1 2004 GTP Problems ?
    Aug 2013
    Canada
    I have a 2004 GTP and it is acting crazy lately.
    My car was telling me to Service ABS, Service Traction Control, Service Stability System. So took it in and had the ABS sensors replaced the beginning of summer. Now my car keeps telling me the I have low wind shield washer even though its full. Low Brake Fluid even though its fine, and you guessed it Service ABS, Service Traction Control, Service Stability System.
    and these light just go on and off
    Any idea what is going on with my car?
  2. #2 Re: 2004 GTP Problems ?
    I would check your wiring harness. Sounds like a loose/bad wire or even a bad ground.
  3. #3 Re: 2004 GTP Problems ?
    Aug 2013
    Foutnain Valley, California
    If I'm not mistaken, the portion of the harness for those items is shared. I agree it could be a wire, but most likely it's a ground like Slick said.
    Portions of the harnesses in these cars are routed horribly and subject to burns, rubbing and inadvertant abuse when servicing the car. Sometimes, the harness connector mounts break and cause strain on the harness wires and connectors. Add all the issues with valve covers leaking oil all over the place, all of the connectors may be in need of a good cleaning. You can get a decent contact cleaner almost everywhere.
    I don't have anything that tells which part of the harness to focus on, but I'm sure someone else may have it.
  4. #4 Re: 2004 GTP Problems ?
    Aug 2013
    Canada
    thank you for your advice i'll take a look at the wiring harness and ground and go from there.
  5. #5 Re: 2004 GTP Problems ?
    May 2013
    Hortonville, WI
    I have had the same issue. It is the wiring harness from the plug by the wheel bearing towards the car. If you go to a parts store some stores will have the factory replacement harness some wont. But if you can get it from advanced auto or o rileys or something like that it will be about half the price it is from gm. gm I think want s real close to 100 for it, and the other stores around here arte at about 48. But that is ur problem its on the car side of the harness, it will come with new plug and about 3 ft. of new wire.
  6. #6 Re: 2004 GTP Problems ?
    Aug 2013
    Canada
    so that problem is fixed now thanks everyone but now my transmission is going and I'm trading the car in.
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 10-03-2014, 06:25 PM
  2. Problems with 2004 GP GT1
    By KirkpatrickJTK in forum General Tech Discussion
    Last Post: 10-23-2011, 01:00 PM
  3. Just bought a 2004 Grand Prix Gtp Comp G but many problems..
    By ThingaMagid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 10:38 AM
  4. 2004 Engine Problems - help!
    By davepond88 in forum Introductions/Noob Questions
    Last Post: 07-23-2010, 04:34 PM
  5. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
