Thread: Top swap while doing LIM?
Results 1 to 20 of 31
  1. #1 Top swap while doing LIM?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    I know my car needs the LIM gasket replaced, with 145k on the clock it's a ticking time bomb for coolant/oil mixture to invade. It seems like if I have to tear the plenum off and the lower intake manifold I might as well do a top swap. I know that for a N/A I will need at least headers to avoid KR. My big concern is tuning, there is no one near close to me that can tune it in car. Southern Virginia doesn't quite specialize in proud car owners so shops that can tune are an abnormality. Is there anything that could be used to record data values so someone like Overkill could tune a PCM for me or do they have to be in the car etc? Further more how much of a chance does my non-hd transmission stand lasting more than 10 minutes with a top swap?
  2. #2 Re: Top swap while doing LIM?
    You realize you have to swap the heads to right?
  3. #3 Re: Top swap while doing LIM?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    For your tune, contact Overkill to get one or you can also purchase a tune from ZZP or 3800performance. You do not need to have your car their. They can send you a tune through the mail. But you may have to send them your PCM, I believe.
    Yes, you should get headers while doing a top swap. Since you have a high compression block, you'll more than likely see more KR on stock manifolds than a typical GTP.
    Your non-HD trans will work.... for now. Be prepared to set some money aside to have it rebuilt with some upgraded parts. These transmissions are built with tinker toys and break all the time. Take me for example, my trans had to be rebuilt twice, when I was stock. But the Non-HD trans is almost identical to the HD trans.
    Lastly, Dan is right, you need to swap the heads as well when doing a top swap. NA heads will not work. Go pull a pair of heads off a GTP from your local junkyard.
  4. #4 Re: Top swap while doing LIM?
    Non hd trans is the same as the hd trans aside from gear ratio and differential
  5. #5 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    Did not know I needed to change out the heads. Well that's a bummer. Looks like I might just do the LIM Gasket, Plenum Gasket, TB Gasket, Coolant Elbows and maybe an HV3 insert or something.
  6. #6 Re: Top swap while doing LIM?
    Jun 2011
    Heads arent that difficult to pull off. Its like 8 bolts per head.
  7. #7 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    My biggest concern is the tune. I know a 'can' tune is not ideal by any means for a top swap.
  8. #8 Re: Top swap while doing LIM?
    Ohio
    You need:
    Supercharger
    L67 Lim
    L67 heads
    L67 harmonic balancer(crank pulley)
    L67 coilpack bracket
    L67 accessory drive tensioner and idler pulley
    L32 map sensor
    New belts
    Refresh some more stuff like radiator hoses, coolant elbows (aluminum replacements are preferred, Dorman PN# 47065hp)
    Headers or plog/downpipe.
    Tune
    May as well do an oil change or two (cheap ones too)
  9. #9 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    I assume I would also need/want a Aeroforce as well to make sure it's done up right.
  10. #10 Re: Top swap while doing LIM?
    Ohio
    It is a good tool to have
  11. #11 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    How would headers run/affect performance on a N/A 3800?
  12. #12 Re: Top swap while doing LIM?
    Jun 2011
    You dont want headers on a NA if your stock other than that.
  13. #13 Re: Top swap while doing LIM?
    Ohio
    Dan if you start with that backpressure bull**** I will flip a ***** on you
  14. #14 Re: Top swap while doing LIM?
    Jun 2011
    Don't know what you're talking about
  15. #15 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    Well if it's not the top swap route, I'd probably just do the LIM gasket and put an HV3 in and then maybe ported manifolds, downpipe etc. just generic air/exhaust mods.
  16. #16 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    Wait a minute, I'm an idiot. I don't know what I was thinking. The valves and everything are contained inside the heads, they just drop right on with new gaskets don't they? When doing the LIM gaskets or the top swap, do the injectors need new o-rings?
  17. #17 Re: Top swap while doing LIM?
    Jun 2011
    Yes, GTP heads just bolt right on. Pull off NA heads, bolt on L67 heads. With new head gaskets, of course.
    Injectors do need new o-rings. Why? Because they are very cheap, and you do not want to take a chance with a fuel leak.
  18. #18 Re: Top swap while doing LIM?
    The Boss Iceman6669's Avatar
    Jun 2011
    Who is talking Back Pressure??
    2011 F-150 Yote powered
  19. #19 Re: Top swap while doing LIM?
    Feb 2009
    Roanoke, VA
    Well hell, I might piece this together over the winter and do it in the spring when I can use the bike as a daily driver. Yeah I've heard one too many horror stories of engine fires from pinched o-rings, I'll gladly replace injector o-rings. On a related note, are the Speed Daddy headers the ones that can be found on ebay for ~$250 or so?
  20. #20 Re: Top swap while doing LIM?
    Jun 2011
    Man. I REALLY hate to be THAT guy, BUT why would you mod an NA at all if you dont plan to top swap or turbo??
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
