Thread: Loose break caliper-girl in need of help
Results 1 to 8 of 8
  1. #1 Loose break caliper-girl in need of help
    Jul 2013
    wi
    I have a 2000 Grand Prix GT and my front passenger brake caliper and rotor are very loose. All the bolts are tight. When I am driving I can hear a thumping sound coming from that side and it gets worse when I let off the gas and slow down without pressing on the brakes. I just got done making sure that the lug nuts on the tire were tight and when I shake the tire, I can see that the caliper moves. So I took the tire off and checked to make sure that the bolts on the caliper were tight which they were. Does anyone have any idea on what could be wrong?
  2. #2 Re: Loose break caliper-girl in need of help
    The brake pads are still inside the caliper correct??
    Only other thing I can think of is a loose tie rod end if you are feeling something loose when you shake the tire at the 9 and 3 postion.
  3. #3 Re: Loose break caliper-girl in need of help
    gardner,mass
    What ffdp said. When you say its loose when you shake the wheel, are you shaking it left to right or up and down? The caliper should be kind of loose cus its supposed to slide inside the bracket but is the actually bracket loose that bolts to the nuckle? are the pads still in the clips inside the bracket?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: Loose break caliper-girl in need of help
    Jul 2013
    wi
    The brake pads are still in there. and it is when I shake the tire from left to right and in and out if that makes sense.
  5. #5 Re: Loose break caliper-girl in need of help
    Feb 2010
    TN
    I am thinking ball joints
  6. #6 Re: Loose break caliper-girl in need of help
    if you grab the tire from the top, push and pull the wheel, jacked up, and the wheel moves, the hub is bad, the rotor will move inside the caliper and pads.
    movement when pushing and pulling from the 3 and 9 o clock positions would be a bad tie rod, or tie rod end.
  7. #7 Re: Loose break caliper-girl in need of help
    Jul 2013
    wi
    Well I replaced the tie rod end yesterday and it fixed the thumping sound and some of the looseness also made my steering feel tighter. But while fixing the tie rod I noticed that the caliper has some scrap marks on the side of it and now instead of the thumping sound, I can hear what sounds like scraping.
  8. #8 Re: Loose break caliper-girl in need of help
    jack the car back up take the wheel off, now look on the inside of the rotor, theres a dust shield there, its metal and runs most the way around the rotor. you may have pushed on it and bent it and now it dragging on the rotor. you just need to bend it back. its thin and no tools should be needed to bend it back.
  1. New Girl from NY
    By lsxftw in forum Introductions/Noob Questions
    Last Post: 06-07-2013, 01:21 PM
  2. what did I break now?
    By skylar44 in forum Brakes/Suspension/Chassis
    Last Post: 08-31-2012, 06:48 PM
  3. Another New Girl
    By DrNoodles in forum Introductions/Noob Questions
    Last Post: 10-12-2011, 01:05 PM
  4. The New Girl
    By OverMyHead in forum Introductions/Noob Questions
    Last Post: 12-16-2009, 12:45 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
