Thread: Ignition
Results 1 to 5 of 5
  1. #1 Ignition
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    So it seems to only do this on a warm start but I'll turn the key and try to start the car then the engine will just click then I'll turn the key back and try to start again right after and it starts up perfect, can't really figure out why it does that click and won't start on the first turn, maybe a spark problem? Ideas please
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  2. #2 Re: Ignition
    loud clicking, and fast when the key is turned from under the hood is a dead battery, or corroded cables.
    or a bad ground on the engine.
  3. #3 Re: Ignition
    Mar 2013
    Fort Lauderdale, FL
    My buddy who I got the car from said the battery is brand new so cables is the only other option?
    1998 GTP Loudmouth
  4. #4 Re: Ignition
    take the cables off the battery, make sure they are clean, and were tight, if one is loose, it will also click.
    the neg cable leads to the tranny bell housing, right above the starter really. bumper side of the engine. make sure its also tight and not corroded.
  5. #5 Re: Ignition
    Mar 2013
    Fort Lauderdale, FL
    Okay thanks ill let you know
    1998 GTP Loudmouth
  1. Need new ignition key
    By jokyfo in forum General Grand Prix Discussion
    Last Post: 06-27-2012, 12:41 PM
  2. ignition
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 05-02-2012, 11:18 AM
  3. ignition key help
    By 03yamahar1 in forum General Tech Discussion
    Last Post: 10-10-2010, 10:06 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
