Thread: Car has shudder or binding feeling....
Results 1 to 13 of 13
  1. #1 Car has shudder or binding feeling....
    Nov 2012
    Maryland
    My wife`s `07 GXP shudders or binds up when accelerating from a stop only. It feels like something is binding up real bad. We thought it was the front calipers seizing up, so I replaced them and also installed new brake pads. Problem still exists. Also the shaking/binding does not happen in low gear, just in drive. So, I guess I can rule out the drive shaft`s U-joints.
    Anyone ever experience this problem or know what it could be?
  2. #2 Re: Car has shudder or binding feeling....
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Not that I can help you, but that doesn't sound very good! lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: Car has shudder or binding feeling....
    Dec 2012
    Where 4T65E's were born
    Wait, so if you put the gear selector in 1'st and take off from a stop, it will not do it? But in Drive it will? That may indicate like a computer problem activating second gear or something while taking off, and it cant when you put it in 1st because you're not allowing it.
    Sold.
  4. #4 Re: Car has shudder or binding feeling....
    Antioch, IL
    trans fluid change?
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Car has shudder or binding feeling....
    St. Louis
    Wonder if that is that is sign that the trans is slipping. Have you checked the fluid? Is it full? Nice and red or brown/black?
    Is the CEL on?
  6. #6 Re: Car has shudder or binding feeling....
    Nov 2012
    Maryland
    Guys, the A/T fluid has been changed last summer and the fluid level is good and has no discolor or bad odor. The check engine light is not on and no codes are stored in the ECM.
    02NavyBlue, do you mean that the transmission may need to be re-programmed?
    I was thinking there might be something wrong with the clutch plates.
  7. #7 Re: Car has shudder or binding feeling....
    Dec 2012
    Well if what I asked was true, the PCM decides shift points; and if a control input is changing whether or not the issue happens, it may be in the control side.
    Sold.
  8. #8 Re: Car has shudder or binding feeling....
    Nov 2012
    Maryland
    Looks like this is probably an issue that a tranny tech will have to diagnose. I hope it is just a minor issue and not a re-build.
  9. #9 Re: Car has shudder or binding feeling....
    Jan 2013
    Indiana
    This may sound stupid but my 01 gtp did the same exact thing , it would shudder like crazy until I got into second gear . I thought I was loosing my tranny , it ended up being bad wheel bearings. Take it for what it is , but I had the car up in the air and checked them and they had no play but when I took them off they were damn near seized up . Replaced them and the shutter went away . Just a thought.
  10. #10 Re: Car has shudder or binding feeling....
    Jul 2013
    Michigan
    Quote Originally Posted by 01gtp1506 View Post
    Car kinda has this shutter, which is very prominant around 40 MPG, but will smooth out if I press on the accelerator. siezing wheel bearings seems very plausible. does anyone else think the wheel bearings could be my problem?
  11. #11 Re: Car has shudder or binding feeling....
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    the car is fwd. it has no driveshaft or u-joints
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  12. #12 Re: Car has shudder or binding feeling....
    Quote Originally Posted by Rather B Blown View Post
    you got U joints, they are in the axle boots. and they do go bad, and do vibrate much like a rwd U joint going bad. if you know what a bad rwd U joint feels like. then you would recognize it rather quickly.
  13. #13 Re: Car has shudder or binding feeling....
    Dec 2012
    Quote Originally Posted by JT18 View Post
    I suppose it's possible. My cousin's wheel bearings got so bad they slowed the car down at all speeds. It felt like the brake was slightly applied.
    Sold.
  1. Sunroof binding? Looking for greasing suggestions.
    By burgundybullet in forum General Tech Discussion
    Last Post: 06-25-2013, 12:26 PM
  2. Odd feeling shifting out of park etc
    By Travisgt2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-09-2013, 10:29 AM
  3. Replies: 1
    Last Post: 04-02-2012, 05:20 PM
  4. Engine binding
    By VolsFan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2009, 11:12 AM
  5. I have a feeling this can't be good..
    By mr2stig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2009, 11:21 AM
