Thread: Do headlights have a clear coat on them?
Results 1 to 15 of 15
  1. #1 Do headlights have a clear coat on them?
    Slower, Lower Delaware
    My headlights are peeling off a surface on the top like a clear coat. What's that?
  2. #2 Re: Do headlights have a clear coat on them?
    Yeah they have a "clear coat" per say, on the 04+ cars they always start to peel there and then spread the rest of the housing.
    Most people just buy news ones when its gone that far.
    Perhaps you could mask off the bottom section, paint the top part black, then clean and clear coat the whole lense to further protect it all.
  3. #3 Re: Do headlights have a clear coat on them?
    Thanks, oh crap.
  4. #4 Re: Do headlights have a clear coat on them?
    The Boss Iceman6669's Avatar
    Jun 2011
    I thought they had a clear GEL coat on them.
    2011 F-150 Yote powered
  5. #5 Re: Do headlights have a clear coat on them?
    Jan 2012
    Philadelphia
    Try and wetsand and buff them see if that helps
  6. #6 Re: Do headlights have a clear coat on them?
    Banned
    Jan 2013
    Colorado
    You can also wax and polish the headlights. That helps protect them for longer.
  7. #7 Re: Do headlights have a clear coat on them?
    Apr 2013
    White Lake
    Try using transmission fluid on them... GF's dad showed me last night when doing my plugs/wires and it defiantly cleared up my lens better then they were!
  8. #8 Re: Do headlights have a clear coat on them?
    There's a light UV coating on them that comes standard but it tends to fail rather quick. Even if you wetsand and polish then you need to put something on then to protect them. I usually use a mineral wax/ paint thinner combo and have had success in the past with mineral wax/ paint thinner combo the yellowing. Or you could have a body shop clear them that should last way longer.
    04 Comp G.
  9. #9 Re: Do headlights have a clear coat on them?
    I have been waxing them.
    Quote Originally Posted by camopaint0707 View Post
  10. #10 Re: Do headlights have a clear coat on them?
    Apr 2013
    White Lake
    You might be able to get the sealer stuff separate that comes out of head light restore kits and apply that to keep em fresh
  11. #11 Re: Do headlights have a clear coat on them?
    04 Comp G.
  12. #12 Re: Do headlights have a clear coat on them?
    Jan 2012
    Philadelphia
    Why do you need something to protect them? Not all factory lights have clear coat on them and they still hold up
  13. #13 Re: Do headlights have a clear coat on them?
    I think the yellowing is more of a issue with plastic headlights vs glass or it could be that different manuf. use different plastic material. Idk the specific to it but from what I've experienced on my car along with friends and family that if you put something on them it slows down the uv coating failing and yellowing rather quick. As easy as wetsanding and polishing is I still rather not have to do it to often as long as I can help it.
    Edit: especially if the car is not garaged kept
    04 Comp G.
  14. #14 Re: Do headlights have a clear coat on them?
    Thanks for the tips.
  15. #15 Re: Do headlights have a clear coat on them?
    Dec 2008
    Lawndale, CA
    I have used this kit before. It works pretty good. Give it a try. You want to put some type of sealer on them or they will turn yellow since there is no type of UV protection on them.
    Sylvania Headlight Restoration Kit : Amazon.com : Automotive
    SYLVANIA Headlight Restoration Kit - YouTube
  1. Clear Coat or no Clear Coat???
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 04-08-2013, 07:03 PM
  2. clear coat after polish?
    By Juanmiguel in forum Tires & Wheels
    Last Post: 12-01-2012, 11:22 AM
  3. Is this clear coat?
    By PioneerGTP in forum Visual/Body Modifications
    Last Post: 10-04-2012, 10:35 PM
  4. clear coat
    By Logan541 in forum Visual/Body Modifications
    Last Post: 07-30-2011, 07:01 PM
  5. Clear coat leaving white spots on tinted tailights what clear coat would u recomend?
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 05-14-2010, 01:31 AM
