Thread: Service Vehicle Soon Message.
Results 1 to 12 of 12
  1. #1 Service Vehicle Soon Message.
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    I have had this Service Vehicle Soon message that popped up on my message center about a 3 weeks ago. I have no check engine, abs, or any kind of warning light going off in my dash. I hooked up a generic code reader and couldnt pull any codes. Has anybody had this problem of have a solution to make it go away. It is very annoying!
  2. #2 Re: Service Vehicle Soon Message.
    service Vehicle soon is the body of the car. good chance your abs light and trac off lights are on as well. maybe a airbag light? or brake light on the dash?
  3. #3 Re: Service Vehicle Soon Message.
    Apr 2013
    Waukesha, WI
    no lights at all in the dash. only the message center message
  4. #4 Re: Service Vehicle Soon Message.
    is everything else is working as it should as far as you know? that light is only for the brakes and body of the car.
    try clearing it, by unhooking the battery, if it comes back you need to get it scanned at a dealer. or a good shop that can read body codes.
    this should have no affect on the engine or tranny. its a separate system.
  5. #5 Re: Service Vehicle Soon Message.
    Apr 2013
    Waukesha, WI
    Well i guess i did replace my brake pads probably 2-3 weeks before i got the message. and I know I need new wheel bearings somewhat soon. Could a wheel speed sensor cause the message if it went to crap?
  6. #6 Re: Service Vehicle Soon Message.
    its the speed sensor in the hub that makes the abs light come on. or bad wires, cut, damaged ect.
    if the bearing is bad enough the sensor cant read right.
  7. #7 Re: Service Vehicle Soon Message.
    Check your headlights and brake lights. You might have one burnt out and I think that'll cause the svs light to come on.
  8. #8 Re: Service Vehicle Soon Message.
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    This ^^^^^.
    Even had it happen on a friends Grand Am. Just a 9007 bulb out.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  9. #9 Re: Service Vehicle Soon Message.
    SWPA
    Could it be the oil life monitor? The monitor doesn't know when you change the oil, so it may not have been reset.
  10. #10 Re: Service Vehicle Soon Message.
    SE Level Member john cola's Avatar
    Sep 2012
    willmar minnesota
    I am going to fix my service engine soon light on my dash today. It involves a small square of black duct tape to cover up the light.
  11. #11 Re: Service Vehicle Soon Message.
    thats not the smartest thing to do. even if its for something you know about, like o2 sensor or egr, or some thing lame, if some thing else goes bad you wont know about it.
  12. #12 Re: Service Vehicle Soon Message.
    Apr 2013
    Waukesha, WI
    Its not the service engine soon light. and I got new headlights and already replaced my side marker lights. Im 99% sure its not a light out. Ill probably take it to the dealership this week.
  1. Service Variable Effort Steering message
    By wildman124 in forum 04+ Specifics
    Last Post: 08-26-2013, 07:55 PM
  2. Service Vehicle Soon message
    By talltree in forum General Tech Discussion
    Last Post: 06-27-2013, 09:02 AM
  3. Service "vehicle" soon, trac off and ABS light all on
    By 98RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 10:45 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Service Vehicle Soon Light, No Codes
    By Luda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:03 AM
