Thread: climate control (please help)
Results 1 to 4 of 4
  1. #1 climate control (please help)
    Jul 2013
    ohio
    hello, i own a 2004 grand prix gt. my blower fan will not switch from defrost to the vents. whenever i turn the knob to defrost the fan slows, when i turn it back to the vents it picks back up. but it does not change over to the vents it stays on defrost.. (stuck in defrost mode)
  2. #2 Re: climate control (please help)
    St. Louis
    Give these 2 threads a read and see if it helps. Sounds like one of the actuators is shot or one of the vac lines may be loose/cracked somwhere.
    http://www.grandprixforums.net/hvac-...elp-76076.html
    http://www.grandprixforums.net/blend...ent-21941.html
  3. #3 Re: climate control (please help)
    Jul 2013
    ohio
    thanks fordman, i parked it one night everything was fine then the next day for some reason it stuck on defrost. i never even turned it on defrost lol. i have tried looking for vaccum lines. while under the dash all i mostly saw were wires and connectors. under the hood it was hard to locate vaccum lines also. but i will try these links and see what i can come up with. once again thanks for your time...
  4. #4 Re: climate control (please help)
    the vac line comes off the engine to the firewall then down the pass side fender, under the fuse box it should have a T there, one side runs into the cab via the wire harness, the other may or may not lead to a vac ball in the driver side fender, it would lead across the rad support to the d/s fender.
  1. climate control
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-19-2010, 11:04 PM
  2. Climate Control
    By GrandprixGearhead in forum General Tech Discussion
    Last Post: 10-30-2009, 11:47 AM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
