Hey guys, is it possible to put the LE cluster in a '97 GTP and everything work? Was thinking '97 has 0-90 ohms resistance and '03 was like 40-240 ohms resistance. All input is greatly appreciated!!!![]()
Well the lights and everything are all the same right? Isn't it just the face itself? I don't know much about swapping clusters, but everything on the cluster is the same from either of those years, so yeah. Not my realm of knowledge, but there shouldn't be much to it honestly.
Fuel gauge will not work, iirc.
And the temp gauge will misread as well...since the values are different...I think those were the two things...speedo, dash lights, and tach would still work just fine...
LE Cluster is from '03, correct? So you'd have the silly little blue Perf. Shift light too.
But, I'm kind of a fan of the way they look.
Oh I mean, I never minded them.
It was a nice change/addition to a overall bland interior.
I'd just guestimate mileage based on the ODO and read coolant temps off the AF gauge/s you got. I found the coolant temps on the AF to be plenty more accurate than where the needle was pointing to anyways.
