Thread: L67 Engine/transmission swap into L36
Results 1 to 4 of 4
  1. #1 L67 Engine/transmission swap into L36
    MO
    I need to be pointed in the right direction. Unless there's a major issue, I have a rebuilt '97 GTP (HD) transmission and a new long block L67 (and reclaimed hang-ons) that I'm wanting to install into my '02 GT L36, Anniversary Coupe. I have an entire '97 GTP car/parts.
    Any issues with using the earlier transmission? Can I use the '97 pcm or do i need to find an '02 GTP pcm? Fuel pump? Any other considerations? Any links/write-ups on the subject would be appreciated.
    Thanks
  2. #2 Re: L67 Engine/transmission swap into L36
    If you are going to swap the wire harness aswell you have to use the 97 PCM.
    But if you want to use the 02 gtp pcm, then you need to a get a wire harness with it.
  3. #3 Re: L67 Engine/transmission swap into L36
    I did a swap into an 01 recently. Used it's original harness and modded the map connector. Not sure why you'd need a different harness. Only difference on the trans..and I'm not sure if you have it or not.. look at your 02 on top of the trans where the cable connects to the armeture that actuates the gear selector. Is there a black box under it like on the 97 trans? If not..I can point you to a post that give you the couple wires you'd need to tap into. It's very straightforward.
  4. #4 Re: L67 Engine/transmission swap into L36
    MO
    Was the swap a '01 to '01 or what years?
    Fairly sure the '02 tranny has the external connect.
    I'm familar with the mod connector, but do I need an '02 GTP PCM (and will it work correctly with '97 tranny - shifts, etc.) or will the '97 PCM work with the rest of the wiring/gauges/etc in the '02 car? I know there's a write up on adding the Perfomance Shift. What about the factory boost gauge? Is the wiring there? I believe the fuel pump wiring is different?
    The wiring/computer is the part that concerns me.
  1. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  2. Engine and Transmission swap from an 04 to a 99 GP
    By 99metalicgtp in forum Introductions/Noob Questions
    Last Post: 07-27-2012, 12:58 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. Transmission Swap
    By cmal37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 08:42 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
