Thread: How much oil is to much?
Results 1 to 20 of 35
  1. #1 How much oil is to much?
    Apr 2013
    White Lake
    2005 GP GT
    Soooo... the other day I decided take my car to a friends house who works on cars. I needed a oil change and didn't feel like driving all the way to my parents house to do it myself so I figured I have him doit. I usually put about 4.5 quarts in engine but when my friend was doing it it told me to poor the whole 5.1 quarts into my engine and said "trust me" its fine.. I read its to much or fine and also read the it should be at the 3 dot any lower is to less or high to more. So I figured I would ask you guys who own these GP's to what is right. If its to much what is the best way to remove the extra oil?
    Thanks!
  2. #2 Re: How much oil is to much?
    I live here. DirtDog's Avatar
    Jun 2012
    I always poured the full five in my old 3.8 when I had it. Its fine
  3. #3 Re: How much oil is to much?
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Turn on the car for about 5 minutes , turn off and recheck oil. If it falls within the hash marks then your good, if too much then unplug the oil drian plug and remove some.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  4. #4 Re: How much oil is to much?
    HUDSON
    If it is above the full line on the dipstick, technically that is too much. It is easy to take some out, and if you want to save it, use a clean drain pan and just pull the drain plug for a second or two and then stick it back in. You might want to wear some disposable gloves just in case it gets messy.
  5. #5 Re: How much oil is to much?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I pour the whole jug in everything for the past 2 years will be no problem. IF there is a problem, what will happen the crank with churn up the oil into a foam. The oil on your dip stick will look like a latte.
    97 Bonneville SE Not so much a 97 anymore
  6. #6 Re: How much oil is to much?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I also put in the whole jug.I have done this for years no problems.then I'll run it for ten thousand kilometers (full synthetic)and the oil be right at the full mark lol(all 3800's burn oil)
  7. #7 Re: How much oil is to much?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    I use 4.5, then after 5k miles I usually top off with the other .5 since it leaks a bit from the pan gasket. I imagine the engineer who designed it put the full line where he did for a reason so I try to not go over that.
  8. #8 Re: How much oil is to much?
    St Thomas Ontario
    they are going to give you a little wiggle room...you know how many people would have a blown engine if you put a little too much oil in lol
    Ur fine guy.drive it with no worries.
  9. #9 Re: How much oil is to much?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I do 4qt and half a bottle of lucas and top off if needed.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  10. #10 Re: How much oil is to much?
    Jun 2012
    Quote Originally Posted by Grimsin View Post
    I also for in the whole jug.I have done this for years no problems.then I'll run it for ten thousand kilometers (full synthetic)and the oil be right at the full mark lol(all grandprix's burn oil)
    Fixed
  11. #11 Re: How much oil is to much?
    St Thomas Ontario
    But I have a impala
  12. #12 Re: How much oil is to much?
    5 quarts ftw.
    The oil pan is huge, could likely handle up to 5.5 quarts before any real foam starts.
  13. #13 Re: How much oil is to much?
    i always dump the whole 5 quarts in, its makes it like 3 mm's over the full line, no big deal, most of use leak oil anyways.
  14. #14 Re: How much oil is to much?
    5 quarts ftw.
    This
    04 Comp G.
  15. #15 Re: How much oil is to much?
    Not all 3800 burn or leak oil. My 98 didn't burn any and my 04 doesn't burn or leak any.
  16. #16 Re: How much oil is to much?
    Nov 2009
    Central Jersey
  17. #17 Re: How much oil is to much?
    I do oatmeal raisin
  18. #18 Re: How much oil is to much?
    Nov 2009
    Central Jersey
    Good choice
  19. #19 Re: How much oil is to much?
    i wish i was in this club, and could have a cookie, oatmeal sound good to me too.
  20. #20 Re: How much oil is to much?
    Mar 2013
    Spring, TX
    I put the whole 5.whatever jug in mine.. now I have oil dripping off of my rear valve cover onto my exhaust and smoking when I first start it.. At least thats what I think it is.
oil
