Thread: Rusted pinch weld remove rack and pinion?
Results 1 to 2 of 2
  1. #1 Rusted pinch weld remove rack and pinion?
    Aug 2012
    MI
    2000 Grand Prix GT 3800
    I would like to replace a leaking steering rack and possibly a stripped 4th clutch hub in the transmission. I cannot support the car from behind the front wheels because it is too rusty and the pinch weld on the drivers side is crushed already from where a previous owner tried to jack up the car.
    Has anyone run into this problem and what did you end up doing to support the car while lowering the subframe to get the rack out?
  2. #2 Re: Rusted pinch weld remove rack and pinion?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Put it on the " frame " under the car close to the tunnel square
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  1. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
  2. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  3. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  4. rack and pinion
    Last Post: 02-21-2011, 09:53 AM
