Thread: tailpipe hangs lower on one side
Results 1 to 14 of 14
  1. #1 tailpipe hangs lower on one side
    SE Level Member blackthunder's Avatar
    Jun 2013
    London, Ontario
    Hello,
    Just wondering what people have done to fix a tail pipe that hangs lower than the other? I see it all the time so im assuming its a common thing.
  2. #2 Re: tailpipe hangs lower on one side
    You can use a hose clamp and put it around the hanger to tighten it up
  3. #3 Re: tailpipe hangs lower on one side
    Get new rubber hangers.
  4. #4 Re: tailpipe hangs lower on one side
    Jun 2013
    London, Ontario
    I'll look into getting new rubber hangers.
    Thanks
  5. #5 Re: tailpipe hangs lower on one side
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Ihad new rubber hangers still hung low on drivers side.. ended up using a hose clamp
  6. #6 Re: tailpipe hangs lower on one side
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    +1 on hoseclamp
  7. #7 Re: tailpipe hangs lower on one side
    Mar 2013
    Webster NY
    previous owner had one muffler replaced on mine and it hung a little low. I put a block of wood on a jack and jacked it up right at the hanger. Bent the hanger just enough to even them out.
  8. #8 Re: tailpipe hangs lower on one side
    I live here. TLSheff's Avatar
    +2 on the hoseclamp. Bought new hangers as well and still hangs low.
  9. #9 Re: tailpipe hangs lower on one side
    Cambridge, Ontario Canada
    +3 I have all new hangers as well & mine are way out
    2005 E55 - stock
  10. #10 Re: tailpipe hangs lower on one side
    Dec 2008
    Lawndale, CA
    Same here. I replaced all of my hangers and the passenger side still sat lower. I ended up using a hose clamp on it to level it out with the drivers side.
  11. #11 Re: tailpipe hangs lower on one side
    Jun 2013
    London, Ontario
    looks like im going to get me a hose clamp. lol. Anyone care to give up the size they got? lol
    Thanks for all the replies guys!
  12. #12 Re: tailpipe hangs lower on one side
    Jul 2011
    Robert, La./Pensacola, Fl.
    Think I used about a 3" hose clamp, just one laying around the tool box.
  13. #13 Re: tailpipe hangs lower on one side
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Do Your Tails Hang Low?
    Do They Rattle to and Fro?
    Can You fix them with a Tie?
    Can You Replace Them and Go?
    Can You Tape Them All Over Like a Ricer-Roni Roller?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  14. #14 Re: tailpipe hangs lower on one side
  1. WTB 97-03 coupe lower driver side molding
    By brian91z34 in forum Wanted To Buy - Parts
    Last Post: 03-05-2013, 11:34 PM
