Thread: Laugh with me at my failing BCM + questions
Results 1 to 4 of 4
  1. #1 Laugh with me at my failing BCM + questions
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Issues
    -TCS wont turn off sometimes
    -everything in the car but the tach will turn off and I have to shut down and restart the car
    -the car wont recognize that you have released the parking brake until you put it in drive and some times not even then.
    -It thinks doors are closed when they are open
    -It thinks doors are open when closed
    -the blower motor will shut off for 3-5 seconds and turn back on.
    -the factory car alarm randomly went off once @ 3am
    Questions
    -Where is the BCM
    -Can I use a junkyard BCM
    -Whats something like that going to cost
    -Could this just be a bad ground
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Laugh with me at my failing BCM + questions
    IIRC the BCM is behind the driver side of the dash. Pop the side panel off and you should be able to see it.
    04 Comp G.
  3. #3 Re: Laugh with me at my failing BCM + questions
    Mar 2013
    Spring, TX
    My factory alarm goes off anywhere from once a week to three times a day. It's pretty random but very annoying.. Especially at work.
  4. #4 Re: Laugh with me at my failing BCM + questions
    Yoga city
    pretty sure you can just get one from the jy, they need to be programmed. Im in the same boat i think, just messes with my idiot
  1. Smog pump failing
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-13-2011, 12:11 AM
  2. Trans failing?
    By AzrakMCSS in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2011, 06:24 AM
  3. Strut mount keeps failing
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2010, 12:37 AM
  4. Disabling my failing emission code checks for emissions this week
    By Quicklynx in forum General Tech Discussion
    Last Post: 03-24-2009, 07:30 PM
