Thread: '99 GTP. Infiniti wheels. How big do I need to bore to clear hub?
Results 1 to 3 of 3
  1. #1 '99 GTP. Infiniti wheels. How big do I need to bore to clear hub?
    Jun 2013
    N/A
    The wheels I have from my old car have the correct lug pattern, but a hub center of 68mm. How big should I get the hub center bored to?
    I know our cars are about 70.30mm hub center size.
    Do I machine them to 70.4mm or 71mm?
    Thanks.
  2. #2 Re: '99 GTP. Infiniti wheels. How big do I need to bore to clear hub?
    St. Louis
    Stock wheel hub bore is 70.30mm, so I would think you'd bore them out to that for a good fit and not have to use hubcentric rings. Why go bigger than needed?
    Question is, what is the offset and size of the wheels from your old car that you are thinking about doing this to?
  3. #3 Re: '99 GTP. Infiniti wheels. How big do I need to bore to clear hub?
    Jun 2013
    N/A
    Quote Originally Posted by FordMan77 View Post
    18x8 30mm offset 2004 Infiniti G35 Coupe wheels.
  1. clear reflector for clear corners?
    By ndgprix in forum Visual/Body Modifications
    Last Post: 03-26-2011, 10:55 PM
  2. bore an LS4?
    By jlt695 in forum 5.3L V8 (LS4)
    Last Post: 01-26-2011, 01:05 PM
  3. Clear coat leaving white spots on tinted tailights what clear coat would u recomend?
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 05-14-2010, 01:31 AM
  4. 2004 GTP vs infiniti G35
    By RageGTP in forum Track Sessions and Kills
    Last Post: 04-19-2009, 01:52 AM
  5. WTF new Infiniti SUV runs 13.5's!!!
    By Smokin2000gtp in forum Off Topic Discussion
    Last Post: 11-23-2008, 07:02 PM
