Thread: Abs, breaking, steering
Results 1 to 6 of 6
  1. #1 Abs, breaking, steering
    May 2013
    Philadelphia
    If anyone ever experienced this problem please let me know what was the problem in the video I posted below those warning lights are all on while I'm driving i have yet to take it to get checked out but when all those warning are on together my steering becomes harder it does not sound like i need new breaks but the handling feel real off almost wobbly http://youtu.be/Hov8hDGa2LY
  2. #2 Re: Abs, breaking, steering
    Video is private.
    But from the sounds on your problem, the ABS light is on.
    And on many cars when the ABS light is on, the magnasteer powering steering system shuts off, thus causing harder steering and will not feel right.
    So either a wheel bearing is bad tripping the ABS light or maybe a wiring issue to one of the hubs.
  3. #3 Re: Abs, breaking, steering
    Banned
    Jan 2013
    Colorado
    braking
  4. #4 Re: Abs, breaking, steering
    May 2013
    Philadelphia
    Thanks I forgot to unlock, I was thinking it was the hub bearings I can feel every little bump in the road and I also hear grinding when turning corners
  5. #5 Re: Abs, breaking, steering
    I'd be guessing at what you are asking. You ask about asking for help if anyone knows what you are talking about and then really don't describe anything. More info will get you better info/responses.
  6. #6 Re: Abs, breaking, steering
    Max Cook
    Guest
    Its probably your EBCM dieing. I would scan for codes first with a scanner that can read ABS codes. If it has codes other than a wheel bearing code its probably your EBCM dieing. Mines dieing too and it definitelly sucks not having magnasteer. You can have these dudes:CHEAP Bosch 5.3 ABS REPAIR VW Passat Audi A4 A6 A8 S4 or Module Masters rebuild/repair/upgrade it or pay a bajillian dollars at the dealership for a new one.
    You can drive without it you'll just lose exactly what you're losing right now (abs,tcs,magnasteer).
  1. Breaking Bad
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 09-30-2013, 06:24 PM
  2. breaking bad
    By z3r0 in forum The Rant Forum
    Last Post: 11-12-2011, 02:46 PM
  3. uh oh breaking in cam
    By Justin48 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2010, 03:57 PM
  4. anyone breaking axles?
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-26-2009, 03:41 PM
  5. Breaking News
    By Abrasive in forum Off Topic Discussion
    Last Post: 12-08-2008, 03:39 PM
