Thread: Please help!
Results 1 to 5 of 5
  1. #1 Please help!
    Jun 2013
    Michigan
    My 2000 Grand prix GT 3.8L 166k miles has been stalling and rpms fluctuate when warm. (can make it not stall by hitting gas pedal).
    I have put a new fuel pump, spark plugs, MAP and wires. I got 3 codes, P0122 - P0650 - P1122.
    Can somebody please help me? Maybe someone has had a similar problem? Side note: Has been to the same mechanic 3 times now he can not figure it out... getting irritated! would love to start driving it again!
  2. #2 Re: Please help!
    What are the codes?
  3. #3 Re: Please help!
    Jun 2013
    Michigan
    ill list the codes below:
    P0122-- Throttle Position Sensor/Switch A Circuit Low Input
    P0650-- Malfunction Indicator Lamp (MIL) Control Circuit)
    P1122--Throttle Position Sensor Circuit Intermittent Low Voltage
    Also, my service engine light is not on.. never has been.. wonder if the bulb is burnt out?
  4. #4 Re: Please help!
    Your tps is probably bad
  5. #5 Re: Please help!
    As well there's something wrong with the SES light. that's code 650. I'd start by checking the bulb. Obviously after you check the TPS and it's wiring.
