Thread: ZZP Poly Transmission mount
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 87
  1. #21 Re: ZZP Poly Transmission mount
    Or that
    04 Comp G.
  2. #22 Re: ZZP Poly Transmission mount
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    If your modded in any way than your gonna have some movement regardless and on that note stock mounts are barely strong enough for the stock motor. The ZZP tranny mount is the only poly tranny mount available for our 3800 and is one of the few solutions to our motor/tranny movement.
    I would think that the guys who are putting down some power have found a way to keep their motor to minimum movement. Hopefully they'll chime in soon.....
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  3. #23 Re: ZZP Poly Transmission mount
    Arizona
    Quote Originally Posted by Dee23 View Post
    see post #20 there are other options
  4. #24 Re: ZZP Poly Transmission mount
    GTP Level Member AjL227's Avatar
    IL
    If you're willing to spend the money or find an LS4 powered W-body donor at the junkyard...
    You can get a differential cover transaxle mount which mounts on the passenger side of the cradle.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  5. #25 Re: ZZP Poly Transmission mount
    Arizona
    Quote Originally Posted by AjL227 View Post
    You will also need the passenger CV axle ,ours are shorter
  6. #26 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Damn, both the write up and LS4 passenger cradle mount sound like great ideas but there's gotta be something simpler. May be there isn't a simpler way but I know a lot of 3800 drivers that are putting down some power that aren't using either of these ideas with minimal motor movement. Now either they're getting some major movement or they have a custom mount supporting that backside near the firewall.
    I may try doing that write up as it sounds very effective, now it appears to look just like ZZP poly trans mount so what internally would keep that home made poly mount from cracking as the ZZP one does as they're both made and supported with polyurethane so there's no real difference or is there?
  7. #27 Re: ZZP Poly Transmission mount
    Arizona
    Simple the poly block I used in the writeup was solid and all you do is drill two holes. I still am running with no issues an no cracks
  8. #28 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    My bad, I totally misread it. Sounds like a plan though. You think it's equal to or better than the ZZP poly trans mount? From the way it sounds your lil modification may be a lil better bc my ZZP poly trans mount only lasted me about 2-3yrs before it cracked
  9. #29 Re: ZZP Poly Transmission mount
    Arizona
    The great thing about mine is you don't have to worry about it splitting cause there's no studs halfway that push pull Internally on the mount. Mine Bolts straight through.
  10. #30 Re: ZZP Poly Transmission mount
    Want to know the best way to keep your motor from moving, buy a Bonneville or PA etc. Something not W body that has all it's mounts down low. Then work on those mounts a little and you'll have no movement.
    I did this with my bonneville, one little tweak to the front mount and poof..engine couldn't move.
  11. #31 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Very true Bill, I noticed that a while back while looking at the bonneville that their motor mounts are much better positioned around the motor unlike mines where they're only on the pass & driver side. GM GM GM......
  12. #32 Re: ZZP Poly Transmission mount
    Yes and no Dee.. the 97 Bvill I had they were one dogbone off the trans diff cover (kept the trans level when you yanked an engine.), on in back of the trans one in front of the trans and one in front of the water pump. You hated that bracket/mount when doing a water pump.
  13. #33 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Im debating as off now wheather I should reuse my poly tranny mount or just buy a new one. I leaning towards a new one bc I only see this one getting worse as time goes by. I've had it to long for ZZP to replace it.
  14. #34 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Recieved my new ZZP poly trans mount yesterday, hope it wont be a repeat of the last one...[IMG][/IMG][IMG][/IMG][IMG][/IMG]
    Crack free for now.....LOL
  15. #35 Re: ZZP Poly Transmission mount
    IL
    Nice, get that bad boy fastened in.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  16. #36 Re: ZZP Poly Transmission mount
    Doing the same thing over and over again ...while expecting different results.. you know the rest...right?
    Search for a post by Tengis on mounts. He fabricated basically what the Bonneville has from the factory. Also look into the 00-05 Bonneville front trans mount bracket. Not the mount..because it was junk but the bracket is spectacular.
  17. #37 Re: ZZP Poly Transmission mount
    Arizona
    It might sound ghetto but why not either lock wire over the whole mount or use a hose clamp. To keep the mount from wanting to pull apart and crack. I'm pretty sure thats probably the issue is the both sides of mount wanting to pull in opposite directions during hard acceleration thus causing the crack.
  18. #38 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Thanx Bill, does the mount bracket bolt right up or do i have to do some modifying?
  19. #39 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Quote Originally Posted by 91parkave View Post
    Yeah I think the ZZP poly mounts are a lil to stiff for our torquey motors. Most mounts need some type of play or a cracked mount is definate to happen
  20. #40 Re: ZZP Poly Transmission mount
    Jul 2012
    North Philly
    Lil update to this thread, so I've put the poly zzp tranny mount in and though it was a direct smooth fit I now have some type of rub. I can feel it in the pedal and seems like the RPMs are being restricted.
    Looked like it cleared everything but I no my previous zzp tranny mount has never done this. Any ideas of where this rub could be coming from? All I could think of was the bolts being to tight or the axel boot rubbing but it seems to clear that.
  1. WTB: One Poly motor mount.
    By Koniig in forum Wanted To Buy - Parts
    Last Post: 03-05-2012, 02:51 PM
  2. Poly Trans Mount
    By Boloknife in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2010, 06:59 PM
  3. Poly mount Questions????
    By basshead42 in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2009, 05:29 AM
