Thread: Grand Prix starts then dies right after "Possible Fix!"
Results 1 to 6 of 6
CyxRyan Grand Prix starts then dies... 05-24-2013, 12:15 PM
STEVEGTX Re: Grand Prix starts then... 05-24-2013, 12:34 PM
Chadgervais Re: Grand Prix starts then... 05-24-2013, 03:10 PM
CyxRyan Re: Grand Prix starts then... 05-27-2013, 04:38 AM
Econdron Re: Grand Prix starts then... 06-03-2013, 08:05 AM
STEVEGTX Re: Grand Prix starts then... 05-27-2013, 01:55 PM
  1. #1 Grand Prix starts then dies right after "Possible Fix!"
    Apr 2013
    White Lake
    So I read an old forum about someone having the same problem as me "Car would start perfect then die right after" He cleaned the Throttle Body and didn't have the problem again. People said it could be the fuel pump not getting enough pressure before you start the engine which probably true for some people. I would HIGHLY RECOMMEND Cleaning your throttle body first "good clean too" and see if it fixes the problem. I used CRC Throttle Body cleaner and its been 1 week of a dozen starts "Cold & Warm" and has not died on me yet.
  2. #2 Re: Grand Prix starts then dies right after "Possible Fix!"
    GTX Level Member STEVEGTX's Avatar
    Oct 2012
    Sleepy Hollow, Illinois, United States
    I had the same problem, I knew it had to be fuel pump because my tb had just been cleaned up after a lim gasket had been replaced. I just took the relay out and bent back the low fuel prong to by pass it
    Thanks TexasTanker19kilo20 for making this^^
    http://www.grandprixforums.net/98-gt...deo-72928.html
  3. #3 Re: Grand Prix starts then dies right after "Possible Fix!"
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Quote Originally Posted by STEVEGTX View Post
    Could you explain that to me? How does that work? Ive had this issue for a year now, and my TB is clean as a whistle.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  4. #4 Re: Grand Prix starts then dies right after "Possible Fix!"
    Apr 2013
    White Lake
    Quote Originally Posted by Chadgervais View Post
    Did you take the TB off and look behind it? I know all cars will have carbon build up but what I was thinking for my situation was that when I started my car it didn't get the right amount of air which would cause it to sometimes die right after, if that makes any sense?
    Still hasn't died yet!
  5. #5 Re: Grand Prix starts then dies right after "Possible Fix!"
    May 2013
    ILLINOIS
    My car had this issue. It would start then die right away. After the second or third try it would start and run fine. Spent $30 and about 5 minutes and replaced the fuel pressure regulator and haven't had ANY issues since (about a week now) and it used to stall EVERY time.
  6. #6 Re: Grand Prix starts then dies right after "Possible Fix!"
    Oct 2012
    I bent back 5 I think gm made a high low in the fuel pump, at low rpms gives less gas and after some time the low goes out so you just do a bypass and make it run on high, its a temporary but sometimes last a good time after doing it
  1. '03 Grand Prix starts then dies right away
    By Econdron in forum General Grand Prix Discussion
    Last Post: 02-28-2022, 11:42 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. not your typical "runs for 3 seconds and dies" thread.
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 09:35 AM
  4. 90 Grand Prix starts, then dies
    By Fishhead5 in forum General Tech Discussion
    Last Post: 06-05-2009, 10:35 AM
