Thread: 99 gp 3.1 random misfire
Results 1 to 2 of 2
  1. #1 99 gp 3.1 random misfire
    Feb 2013
    USA
    occasionally my check engine light comes on i get a random misfire code. usually happens under acceleration/high rpm. My battery also doesn't hold much of a charge eg. if i leave radio on 15 20 min car wont start. could this cause my misfire?
  2. #2 Re: 99 gp 3.1 random misfire
    Bad battery won't cause a misfire.
    Could have a failing alternator or battery...your local auto parts stores will check those for free. Also, leaving the key in the "on" positon will drain the battery, use the accessory...that's what it is there for.
    As for the misfire. Get new spark plugs/wires...start there. Clean the coil pack terminals when you remove the old wires as well.
  1. GTP random misfire/hesitation
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2013, 09:43 PM
  2. Random Misfire
    By rhea0032 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 09:11 PM
  3. Random Misfire
    By SamGT in forum General Tech Discussion
    Last Post: 01-06-2012, 07:20 AM
  4. Random Misfire
    By BlackSun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 12:22 PM
  5. Random Misfire
    By Diegogrande in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2009, 10:18 AM
