Like 70% of the time when I start my 2005 GP it will start right up but then a second later it will die. I will usually then start it back up then tap the gas and everything is fine. What would cause the engine to start then die a second later? To me it seems like its not getting enough fuel to start or it could be my battery I have which CA is 440 which seems a little bit low as I said in a previous thread. I just don't want to throw 100 into a better battery and it still do the same thing. I've already put all new brakes and rotors, Thermostat and just replace the plastic elbows because one cracked and cause a massive radiator leak.... Ughh!
