Thread: Battery Drain
Results 1 to 7 of 7
  1. #1 Battery Drain
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Greetings
    I have a new 800cca Autocraft battery in my car purchased in November. How long can I run the radio with the engine off? Also, would it cause a serious drain to keep my GPS plugged in full time? Of course it would be off, but still drawing current to keep the GPS unit's battery topped off.
    I see on the battery label "Reserve Capacity 120 minutes". I assume that means the battery could keep the engine running for 120 minutes should the alternator fail completely?
    Thanks.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  2. #2 Re: Battery Drain
    Your gps is draining your battery. Unplug it when you're not using it.
  3. #3 Re: Battery Drain
    Dec 2012
    Where 4T65E's were born
    "Reserve capacity is the number of minutes a battery can maintain a useful voltage under a 25 ampere discharge." I would also suggest removing the charger cord for the GPS when you don't need it. Or plug it into an outlet that turns off when the key is removed. My friend has a GPS wired in permanently, and his battery goes dead after a week.
    Sold.
  4. #4 Re: Battery Drain
    Sep 2012
    Bangor, ME
    Is there such an outlet on the '04? The times I have left a phone charger plugged in, I come back next morning and its green indicator light is still on. Also, I NEVER go a week without using my car. Since I have owned it, I have driven it every single day, no exceptions.
    GOD BLESS...
  5. #5 Re: Battery Drain
    its best to always unplug stuff. a left on light can kill a battery over night most of the time as well.
    oh, and even if you turn it off, but leave it plugged in, if the light is still on on the charger part, its using power still.
  6. #6 Re: Battery Drain
    you can re wire the outlet to power off when the car is turned off, you just need a new power wire to the socket. its already got a ground wire there.
  7. #7 Re: Battery Drain
    Dec 2012
    Yeah I just found out both of my outlets stay on with the key off. I must be used to how dodge does it.
    Sold.
  1. Constant Electrical Drain Running Down The Battery
    By falcongt in forum General Tech Discussion
    Last Post: 11-06-2017, 07:09 PM
  2. How to drain
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 12-24-2012, 09:19 PM
  3. confusing battery drain...help!!!
    By twol8uluz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 01:48 PM
  4. HID Battery Drain
    By Lishap in forum 04+ Specifics
    Last Post: 06-18-2012, 11:53 AM
  5. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
