Thread: Starts then nearly dies?
Results 1 to 11 of 11
  1. #1 Starts then nearly dies?
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    Hey there, I'm just wondering what the issue is with these generation 3 engines? I would think it was only my car but I have a sister that has the same year (2004) Grand Prix, just minus the supercharger I have and both suck at starting. You'll start the car and she'll idle down to an unhealthy RPM then kick back up. It seems like it gets a shot of fuel at first then chokes off for a bit? It's not a huge issue I just wanna know if maybe there's some hidden filters that need changing or a cat that should be ripped out? Any suggestions or inputs? Thanks!
  2. #2 Re: Starts then nearly dies?
    Dec 2012
    Where 4T65E's were born
    I test drove 3 04+ Grand Prix's before settling on my 02, and all of the 04+ grand prix's studdered a bit when starting, and on two of them you had to give it a little gas to keep them going when starting. After they got running it was fine.
    I always suggest cleaning the throttle body and cleaning the MAF sensor (each have their own specific cleaner) at the same time and seeing if that fixes the issue. If not, tuneup items should be looked over/replaced.
    Sold.
  3. #3 Re: Starts then nearly dies?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Dirty throttle body. Seen dozens.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: Starts then nearly dies?
    Yep it's 99% of the time the tb.
  5. #5 Re: Starts then nearly dies?
    Apr 2013
    Saskatoon, SK
    Yeah, I should have done that when I did my LIM job last Sunday. I was checking it over and it's dirty. Can I use carb cleaner on that? Or is there other recommended cleaners to use?
  6. #6 Re: Starts then nearly dies?
    Dec 2012
    Quote Originally Posted by hammerline81 View Post
    You can usually use carb cleaner. Some throttle bodies have a certain coating that will be ruined by it. But they usually have a warning sticker on top of them.
    Sold.
  7. #7 Starts then nearly dies?
    Omaha, NE
  8. #8 Re: Starts then nearly dies?
    Apr 2013
    Saskatoon, SK
    Yeah, I'll just buy a tooth brush and carb cleaner and ill go to town on it. See if she's good. I'll change the fuel filter too, I'm sure that'll have to be done.
  9. #9 Re: Starts then nearly dies?
    Dec 2012
    I'm not sure of the series III setup, but on the series II, the MAF sensor is in the throttle body, and you cannot get any carb cleaner on the MAF. So make sure it's removed from the throttle body before cleaning the throttle, if it's set up that way.
    Sold.
  10. #10 Re: Starts then nearly dies?
    I'm not sure what you were thinking, but I am pretty sure you got II and III confused.
    II maf in TB
    III maf right next to airbox.
  11. #11 Re: Starts then nearly dies?
    Dec 2012
    Right, that's why I said "I'm not sure of the series III setup". Point being don't get any on the maf.
    Sold.
  1. 98 GTP starts and dies intermittently on cold starts
    By toadson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2013, 07:53 PM
  2. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  3. starts and dies
    By betsgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 08:56 AM
  4. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
  5. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
