you got it buddy
Dan.. Anthony Smith is selling 300m's for about $100 lower than ZZP, might be a win for you. 3.29's will actually make it easier to leave the line, 2.93's would have a tendency to spin faster with less rpm and since you have plenty of power to break them free... you get the point. Although the top end suffers a little based on the gearing.
You should probably have the pins welded on the ISS reluctor as well.
I did see that FS thread and have been thinkinng about it for sure... been spending too much money lately and havent pulled the trigger yet. If only i could magically come up with 2700 for Swig's trans if he doesnt sell it first LOL.
... weld pins when trans apart.. check
pic updates. Got some stuff done today... Had to play with the wiring in my subpanel to my shop... and ended up wiring the Tig welder direct to the 100amp breaker. LOL i consulted my electrician buddy first to be safe. Still a little work to do. fmhe and turbo IC are mounted. Just have to get the right fittings for the coolant lines and i ordered up a few IC piping pieces.
Pics of my buddy mike @tuningalliance.com doin work (if you have a subie, mazda or nissan see website for killer maps)
Pics of FMHE and turbo IC installed with new mounting tabs welded up!
[URL=http://s1158.photobucket.com/user/danomite02/media/twincharged/DSCN0672.jpg.html]
getting there....
Looking awesome Dan.
Did you have the aluminum subframe before? Some of the locals with good horse found they started breaking the welds with a few hard launches. Just something to keep an eye on.
Looking good! Must be rocking a Miller Tig?
pic updates!!
IC fill neck $2.50 on ebay LOL
IC pump relay neatly tucked in. I also discovered that on the side of the engine bay fuse box, are slots that allow you to slide a Delphi fuse holder onto the side of it for perfect mounting!
I think phil was right in the last thread, the pump may push the water through the one core and not the other. Even if they are the same diameter hoses, the distance and resistance of gravity may cause issues for flow to 1 core.
this is insane. do you have a wife? i dont see how you can devote so much time and money into your car if you do, if she lets you do this, give me her number so i can work some of my magic
hahahhaha im engaged, been together almost 4 years now. As for time and money, i have at least 3 hours after work every day i can work on it, and she works every sunday so thats a full day of work if i chose. And being a union fire sprinkler fitter pays the bills.
and for the record, she hates my car LOL. But she knew when we got together that my car, my jeep and my guns are here to stay so she deals with it
