Thread: What spark plugs/wires should I get?
Results 1 to 14 of 14
  1. #1 What spark plugs/wires should I get?
    Apr 2013
    White Lake
    I'm looking to get some good decent spark plugs/wires for my 2005 GP GT. I don't want the cheap stuff so i'm in the middle between cheap and performance plugs/wires. I was looking at some AC Delco Wires which are $43.99 & AC Delco 41-101 Plugs which are $6.99 a piece. How well do these perform to others brands and also what other plug/wires do you guys suggest for a GP?
  2. #2 Re: What spark plugs/wires should I get?
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    Depends on ur mods man...Many recommend the simple stock GM wires and 605 plugs or 104(i think). The GM wires arent as pretty under the hood as the red ones you see often but ive been told there better than the others sold at zzp
    Sent from my SCH-I535 using Tapatalk 2
    Top-Swapped GT, SLP headers, 3.2 Pulley, Stage 2 Intercooler
  3. #3 Re: What spark plugs/wires should I get?
    Omaha, NE
    GM/Delco
  4. #4 Re: What spark plugs/wires should I get?
    Autolite plugs cheap wires
  5. #5 Re: What spark plugs/wires should I get?
    Dec 2012
    Where 4T65E's were born
    I'd use the stock stuff. It is $6.99 per plug and wires are around $45 = ~$87 But if you go online to amazon, they have the same plugs for 5.93 each, and the same wires for $26.82. Also there's a rebate for AC Delco plugs to save $2 per plug, which is a lot. You'd spend around $50 instead. Links:
    ACDelco 41-101 Professional Iridium Spark Plug, Pack of 1 : Amazon.com : Automotive
    ACDelco 9746BB Spark Plug Wire Kit : Amazon.com : Automotive
    http://www.acdelco.com/pdf/Spark%20P...ate%20form.pdf
    Sold.
  6. #6 Re: What spark plugs/wires should I get?
    Apr 2013
    White Lake
    Thank you very much 02NavyBlue =D
  7. #7 Re: What spark plugs/wires should I get?
    SE Level Member HEVEYMETIL's Avatar
    Western New York
    And if you're removing the dog bone bolts and rocking the engine forward - make sure you haven't broken anything in the process. I found out the hard way to not pull on stuff when you don't know its purpose. I ended up having to replace a broken MAP sensor (1 of 2) for our cars.
    The guys on here helped me out very much. Be gentle as possible - except when removing the stock wires, cuz that aint' possible.
  8. #8 Re: What spark plugs/wires should I get?
    Apr 2013
    White Lake
    haha alright I will keep that in mind!
  9. #9 Re: What spark plugs/wires should I get?
    May 2011
    winnipeg
    I used ac delco 41-101 plugs and NGK blue jacket wires. Runs and accelerates better than the last set of new delco wires
  10. #10 Re: What spark plugs/wires should I get?
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Been through a few sets of wires and plugs, OEM (Bocsh type wires) seem to be the best for me so far. There's other wires that claim to be this and that but at the end of the day they aren't. Looks are one thing but longevity and durability is everything (please dont go for those $125 PRJ wires unless you plan on never taking them off, it's a bi**h & not worth it).
    Plugs, I settled for the NGK V-Power TR6 #4177(these are 2 heat ranges colder so get the ones that fit your mods, maybe the TR55.Same plug just one heat range colder), instant difference, smooth acceleration, and no more dead spots and hesitations.
    If you want a lil style go with the Taylor wires from PFYC.com. Not sure about everybody else but they lasted me about 5yrs(still had life I only changed them bc of the simple fact that they were old).
    Dee....
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  11. #11 Re: What spark plugs/wires should I get?
    they're one range colder.
    tr5 is factory temp.
    Is the OP's car even modded?
  12. #12 Re: What spark plugs/wires should I get?
    Jul 2012
    North Philly
    Which plugs are one heat colder? I couldve sworn the NKG V-power TR6 #4177 were 2 heat ranges colder.....
  13. #13 Re: What spark plugs/wires should I get?
    May 2013
    Hortonville, WI
    i would stick with the stock plugs for sure they work the best been there done that with the supposid high performace plugs with the 3.8's and they dont like ne thing else!!!!!!!!!
  14. #14 Re: What spark plugs/wires should I get?
    Pennsylvania
    stock plugs and wires will not do you wrong.
  1. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  2. best spark plugs and wires for my gtp?
    By tichota126 in forum General Tech Discussion
    Last Post: 05-14-2012, 12:14 AM
  3. 07 GT spark plugs and wires
    By E IN v Y in forum General Tech Discussion
    Last Post: 10-05-2011, 10:27 PM
  4. Spark Plugs & Wires
    By nchurik in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2010, 01:50 AM
  5. New Spark Plugs and Wires
    By rileystanek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 02:31 AM
