Thread: Took my 04 to the dyno yesterday
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 151
  1. #21 Re: Took my 04 to the dyno yesterday
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by Matt Palm View Post
    867-5309
    Matt I think that number is older than you bro.
    Tommy Tutone - Jenny (867-5309) (Original Studio) - YouTube
    Matt-1993
    Jenny(8675309)-1981
  2. #22 Re: Took my 04 to the dyno yesterday
    Headers would make very little difference in the torque this car makes
    Maybe not however it will make a difference in the hp esp if you change the injectors and pulley down which in return would gain back whatever tq lost by adding headers still money well spent. I know you've built and had faster cars which still confuses me even more why you refuse to do the simple things to make the most from that xpz cam..........
    Ohh and post the numbers it made already!
  3. #23 Re: Took my 04 to the dyno yesterday
    I read this whole thing and saw no dyno numbers.
    Wooooooooooooooooo.
  4. #24 Re: Took my 04 to the dyno yesterday
    Ohio
    Matt-1993
    Jenny(8765309)-1981
    8675309*
  5. #25 Re: Took my 04 to the dyno yesterday
    Nov 2012
    Madison
    Jeepers already...272/?
  6. #26 Re: Took my 04 to the dyno yesterday
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    where the dyno number wtf
  7. #27 Re: Took my 04 to the dyno yesterday
    Sep 2011
    Heaven forbid marines and unicorns visit this page before numbers are posted.
  8. #28 Re: Took my 04 to the dyno yesterday
    over 9000
  9. #29 Re: Took my 04 to the dyno yesterday
    Banned
    Jan 2013
    200 and a blown head gasket lmao
  10. #30 Re: Took my 04 to the dyno yesterday
    May 2008
    Schuyler, NE
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Headers won't make anymore power either.
  11. #31 Re: Took my 04 to the dyno yesterday
    May 2008
    Schuyler, NE
    Anyways first pull with the stock airbox:
    264hp and 275ish tq
    Pulled that off, and stuck a filter on the MAF for the second pull:
    266hp and 278tq
    It was still running pretty rich, but almost a dead even afr across the board, so I changed my base PE table from 11.1 to 11.3. And, for whatever reason, it went ran richer. Most of the pull was ~10.9afr.
    259hp and I don't remember the tq.
    I told myself that I would be happy with 260whp before I went in. This is one of those dyno's that break hearts, so I was pretty happy with what I made. It's pretty common for most people to lose 15-20% on this dyno from the dynojet that's in town.
    My injectors are at 100% duty cycle at 5100 RPM's, so my next mod will be some bigger ones. I may try to get it to the track first, but I'm sure with that high of a DC, I'm losing a decent amount of power in the upper RPM's.
  12. #32 Re: Took my 04 to the dyno yesterday
    GTP Level Member AjL227's Avatar
    IL
    To what degree are the heads ported?
    How many #'s are you seeing, like 3-4?
    I'll say..
    254whp/313wtq
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  13. #33 Re: Took my 04 to the dyno yesterday
    Was expecting more TQ after all this no need for headers spew..........
  14. #34 Re: Took my 04 to the dyno yesterday
    May 2008
    Schuyler, NE
    Quote Originally Posted by AjL227 View Post
    I'll say..
    254whp/313wtq
    I spent about 30 hours porting and polishing the heads for it. I have some pictures posted in a thread I started on TCG.
    And, I don't understand your other question.
  15. #35 Re: Took my 04 to the dyno yesterday
    May 2008
    Schuyler, NE
    Uhhhh...what?
  16. #36 Re: Took my 04 to the dyno yesterday
    I'm left thinking the same if your hp and tq numbers are that close together..........
  17. #37 Re: Took my 04 to the dyno yesterday
    IL
    Boost. Pounds. PSI.
    I'm trying to picture how well your heads flow considering your cam profile and minimal s/c output.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  18. #38 Re: Took my 04 to the dyno yesterday
    Given what zzps site says for the cam it should support 3.0 on a non ic engine and the dyno sheet shown on that pages also shows 400 plus hp and 400 plus tq.
    (yes I get it that car has way better heads is intercooled and on a way smaller pulley that's not my point)
    given the info on the cam and staggered pushrod length for intake and exhaust. I can understand the engine hp and tq numbers climb almost parallel to each other. Which mirrors your hp and tq numbers.
    All of this still makes me believe headers injectors and a smaller pulley with another tune obviously would make this car an entirely different animal!
    Btw please explain how injectors and a smaller pulley would help when its still being choked out? Can't cram more air in if you can't get it out.......
  19. #39 Re: Took my 04 to the dyno yesterday
    May 2008
    Schuyler, NE
    Boost. Pounds. PSI.
    Ah, ok. I guess I'm not really sure. Back in December, I was showing about 6psi iirc. So, maybe 5???? I haven't scanned boost for awhile.
  20. #40 Re: Took my 04 to the dyno yesterday
    May 2008
    Schuyler, NE
    Because, exhaust manifolds are not a restriction. The car is having no trouble getting the air out. I don't understand where you are getting this idea.
    No way you will see 400whp without an IC. I'm guessing with some race gas, pulley, and injectors, the car would maybe make 350.
  1. Bought my first GP yesterday
    By RockPilot in forum Introductions/Noob Questions
    Last Post: 04-19-2012, 05:42 PM
  2. got some codes yesterday
    By BlackGT97 in forum General Tech Discussion
    Last Post: 09-30-2011, 07:37 PM
  3. Lost Yesterday
    By eightyseven in forum Track Sessions and Kills
    Last Post: 09-26-2011, 06:04 PM
  4. Went to court yesterday
    By stkks in forum Off Topic Discussion
    Last Post: 01-08-2009, 04:28 PM
  5. I got my 18's on yesterday!
    By xbnb1978x in forum Tires & Wheels
    Last Post: 10-23-2008, 09:37 AM
