Thread: vibration at high speeds after lowering
Results 1 to 5 of 5
  1. #1 vibration at high speeds after lowering
    GT Level Member des19's Avatar
    May 2011
    Ontario
    I have had my car lowered on SSCs now for about 8 months and the only thing i really noticed in change was a vibration at wot at very high speeds only. Only happens at around 110 km/h or 68 mph. When i hit it going this fast i get vibration. Would installing shorter dogbones help this?
    why would it only vibrate at high speeds and wot?
    thanks
  2. #2 Re: vibration at high speeds after lowering
    How are your engine mounts? Did you install some pogo washer and instead of shorter dogbones get some Vinnie spacers.
    04 Comp G.
  3. #3 Re: vibration at high speeds after lowering
    May 2011
    Ontario
    didn't really check the engine mounts, car only has 70 000 miles on it. I installed 4 pogo washers with the install, nothing else.
  4. #4 Re: vibration at high speeds after lowering
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I had this problem in my 02 I replaced both axles, Now i have no more vibration
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  5. #5 Re: vibration at high speeds after lowering
    Motor mount spacers is what I would do to correct the axle geometry from lowering.
  1. Vibration at highway speeds
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 08:10 PM
  2. Vibration when hitting the brakes at speeds above 30mph
    By IFrees in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2010, 06:59 PM
  3. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  4. Boost lost at high speeds. Help?
    By pizzi22 in forum General Tech Discussion
    Last Post: 11-06-2009, 11:28 AM
  5. vibration at highway speeds
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 07:42 PM
