Thread: rotor touching ebrake, wheel hard to turn.
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
  1. #41 Re: rotor touching ebrake, wheel hard to turn.
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Wait - you have uneven wear on your pads? Did you push the caliper piston all the way in? If you have uneven wear on your pads, you probably have a bad caliper...especially if you are unable to recess the piston...
  2. #42 Re: rotor touching ebrake, wheel hard to turn.
    Quote Originally Posted by raverockstar View Post
    So I'm talking about the knuckle.
    One of the bolts was over screwed in. Which pressing the brake too tight on one side. Which is wrong cz the other bolt of the knuckle is screwed all the way but fine. But the bolt on the right side is over screwed. I opened it a little bit so it will be even.
    im confused, post a pic of what your talking about. if you can.
  3. #43 Re: rotor touching ebrake, wheel hard to turn.
    Aug 2012
    Tukwila, Washington, United States
    Quote Originally Posted by loopy View Post
    Yes and yes.
    Grand Prix gt 1999 v6 3.8L coupe.
  4. #44 Re: rotor touching ebrake, wheel hard to turn.
    Aug 2012
    I will when I get home.
    Thank u.
  5. #45 Re: rotor touching ebrake, wheel hard to turn.
    Dec 2012
    Where 4T65E's were born
    I've got all of my brakes off on all 4 wheels of my 02 Grand Prix, I can post a picture of what they look like. I'll edit this once I get them uploaded.
    From the top
    From the bottom. That looks like an adjuster
    Sold.
  6. #46 Re: rotor touching ebrake, wheel hard to turn.
    SWPA
    You have two bolts that hold the bracket to the hub, and two bolts that bolt the caliper to the bracket. ALL FOUR OF THOSE BOLTS NEED TO BE TIGHT.
    DO NOT, DO NOT, DO NOT
    leave them loose in the slightest. Even though you can't loosen them by hand, doesn't mean they wont work themselves loose in normal driving.
  7. #47 Re: rotor touching ebrake, wheel hard to turn.
    Dec 2012
    For the sake of safety I'll go out and take a picture of that
    Sold.
  8. #48 Re: rotor touching ebrake, wheel hard to turn.
    Aug 2012
    I will do it when it stops raining.
  9. #49 Re: rotor touching ebrake, wheel hard to turn.
    Dec 2012
    Here's a good picture of the bolts that must be tight:
    FRONT BRAKES:
    Bleeder Valve
    13 N?m 115 lb in
    Brake Hose Bolt
    54 N?m 40 lb ft
    Caliper Bolts
    85 N?m 63 lb ft
    Caliper Bracket Bolts
    185 N?m 137 lb ft
    REAR BRAKES:
    Bleeder Valve
    11 N?m 97 lb in
    Brake Hose Bolt
    44 N?m 32 lb ft
    Caliper Bolts
    43 N?m 32 lb ft
    125 N?m 92 lb ft
    Sold.
  10. #50 Re: rotor touching ebrake, wheel hard to turn.
    SWPA
    Not to mention that the bolts that hold the bracket to the knuckle are supposed to have loctite on them. Technically according to the FSM you are supposed to replace those bolts if you remove them. I personally find that ridiculous, especially considering the OEM bolts cost like $18 each.
    I ended up buying new bolts from Fastenal and applying loctite.
  11. #51 Re: rotor touching ebrake, wheel hard to turn.
    Aug 2012
    Well I checked the rear caliper again. It's ok.
    Everything is tight but one knuckle bolt that is almost all the way tight and doesn't turn by itself.
    I think I'll let the pads wear out the faulty shape and ill tight it more later. Btw that's how it was before I bought the car. The old pad had a wear shape on one side more than the other, that side is the one with the knuckle bolt that was over tight.
    I think It's better this way than rotor rubbing it and get hot and melt.
  12. #52 Re: rotor touching ebrake, wheel hard to turn.
    Nov 2012
    Madison
    Raver your scaring everyone...if you get some time this week, and your car is still in one piece, you should really get some pics of your actual setup. Then use paint and put some marks on the photos do explain yourself better. As it stands I would think the general consensus would be that your reasoning is flat out wrong and quite dangerous.
  13. #53 Re: rotor touching ebrake, wheel hard to turn.
    May 2012
    Ohio
    I should have known by the racing stripes that reading this would give me a headache. Whatever you do, don't follow me anywhere - I got more faith in a semi on ice being able to crank it to a hard stop. See Bill's comment about selling tools on page 1.
  14. #54 Re: rotor touching ebrake, wheel hard to turn.
    Aug 2012
    Ok everything is ok now. Now I can screw it all the way and the wheel is free.
    The pad got the shape.
  15. #55 Re: rotor touching ebrake, wheel hard to turn.
    SWPA
    Something is still wrong if you had to shape the pad. Something isn't sitting right. You are going to have more uneven pad wear.
  16. #56 Re: rotor touching ebrake, wheel hard to turn.
    Dec 2012
    I think he was confusing a little bit of resistance in the wheel moving after initially reinstalling the caliper, it will rub a little at first if the caliper slides on tight, but brake and release a few times and it should rub still, but not slow the wheel too much. You'll just hear a slight grinding noise when the wheel is off the ground and spinning. He was also confusing the bracket bolts and/or the caliper pin as adjusters. They are never a way to adjust anything. That little star wheel on the e-brake is the only adjustment on our 4-wheel disk brakes.
    Sold.
  1. When I turn the wheel......
    By Der2z in forum Brakes/Suspension/Chassis
    Last Post: 11-30-2012, 06:41 PM
  2. Ebrake light when ebrake not engaged
    By 7point62 in forum General Tech Discussion
    Last Post: 08-22-2012, 06:22 PM
  3. Changed Power Steering Pump and Wheel is still hard to turn...Why??? Plz Help!!
    By nickdemio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-23-2012, 05:57 AM
  4. wifes car hard to turn
    By gpgtman83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2010, 12:51 AM
  5. hot wheel/rotor
    By yourTVlies in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2009, 09:59 AM
