Thread: GT fuel pressure regulator replacement
Results 1 to 7 of 7
  1. #1 GT fuel pressure regulator replacement
    Apr 2013
    Cedar Rapids
    Okay, so my uncle recently replaced my fuel pressure regulator and fuel filter. He told me to get the parts and went to Auto Zone. I got the parts and when he put the regulator in, it was the wrong size so he ended up putting the supercharged regulator in it. Anyone else that has replaced the pressure regulator for the 3.8 v6 engine have this issue?
  2. #2 Re: GT fuel pressure regulator replacement
    St. Louis
    When getting parts from Autozone, yes. You're best bet is to look the part up yourself online and take the part number in with you so they don't screw it up.
  3. #3 Re: GT fuel pressure regulator replacement
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    I always open the box and make sure it is the right part. About 10 years ago, I had a solenoid boxed wrong. Took 2 back before I realized the store had a case of them boxed wrong. Not really their fault, the box was right but wrong part inside.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  4. #4 Re: GT fuel pressure regulator replacement
    Yep, i've found that there are different ones based on the year of the car/fuel rail if motor has been swapped.
  5. #5 Re: GT fuel pressure regulator replacement
    Apr 2013
    Cedar Rapids
    When the original pressure regulator was taken out, the screen in it was busted. That was the cause of the car not starting all the time
  6. #6 Re: GT fuel pressure regulator replacement
    Actually it appeared busted, likely it was fine. I also thought the same thing. The o-ring is the only thing that barely holds the screen in place. When you pull the old out, you have to fish the screen and ring out everytime.
  7. #7 Re: GT fuel pressure regulator replacement
    Apr 2013
    Cedar Rapids
    Well, the new one works great. Before, I had to start it twice or three times sometimes and sometimes there was smoke that came out
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. Fuel Pressure Regulator
    By RotyP in forum 04+ Specifics
    Last Post: 10-22-2011, 12:41 PM
  3. Hey wtf?! No fuel pressure regulator???
    By TheYanz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2011, 07:05 AM
  4. Fuel Pressure regulator
    By xxch4osxx in forum General Tech Discussion
    Last Post: 09-08-2009, 06:26 AM
