Thread: Catalytic converter question?
Results 1 to 20 of 22
  1. #1 Catalytic converter question?
    Aug 2012
    Prestonsburg, KY
    Hey gang. Now that we're past the coolant temperature sensor problem on
    my son's 2001 Pontiac Grand Prix GT (3800 motor), it's time for the next
    problem.
    He is still complaining that it doesn't *quite* have the power that it had
    when he first got it. He slapped it on the computer and right now its only
    showing some kind of environmental equip. error (kinda vague to me). One
    of his friends has a garage and gave it a quick once-over. He told my son
    that his best guess was that the catalytic converter was going or gone.
    We looked up the price at Advance and those danged things are $170-240.00,
    pretty expensive stuff for an older car.
    Is there any cheaper ones or can anything <cough> else be done, like replacing
    it with a straight pipe, reaming the current converter out, or some solid after
    market solution?
    We live in Kentucky so we don't have to worry about California stuff.
    Thanks for any and all help.
  2. #2 Re: Catalytic converter question?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Don't go with a cheap or universal cat. It will throw a P0420 "almost" instantly.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  3. #3 Re: Catalytic converter question?
    Sep 2011
    MI
    You can strait pipe it. you'll probably get a catalyst innefficency code from the rear 02 sensor but it shouldn't cause any driveability issues. thats the cheapest route.
  4. #4 Re: Catalytic converter question?
    Quote Originally Posted by 99PontiacGTP View Post
    If only you knew.
    01+ has cat diag in the PCM, it needs a cat there to not get crappy gas mileage.
    And nobody better say "get a tune to fix that" because not everybody knows what those words mean or know anybody that can even do it.
  5. #5 Re: Catalytic converter question?
    St. Louis
    If only you knew.
    Ok, how's about he "aquires a program modified ECU to resolve the issue"?
  6. #6 Re: Catalytic converter question?
    Don't be a smart ass now.
  7. #7 Re: Catalytic converter question?
    GT Level Member GrandprixGT01's Avatar
    Nov 2011
    Keswick, Ontario
    Good time to get the 2.5 inch downpipe with high flow cat from zzp.
    2003 GT: Wizzair CAI, Flipped Dog Bones, MagnaFlow Mufflers, SE Exhaust Tips
  8. #8 Re: Catalytic converter question?
    Apr 2012
    Goderich, Ontario
    I got the ZZP 2.5" cat'd dp, still throws the code. Light has been on for about 8 months now.
    -Paul Walker
  9. #9 Re: Catalytic converter question?
    Nov 2011
    Keswick, Ontario
    Quote Originally Posted by smoke14 View Post
    How much did the shipping come to for the 2.5" dp? I have been thinking about getting it for a while now.
  10. #10 Re: Catalytic converter question?
    Apr 2012
    Goderich, Ontario
    Was $220 I think to my door. $160 for the part, $40 for shipping and $20 brokerage fee at the border. Then installed it myself. The cat isn't Magnaflow as advertised, it's CanAmMex.
    -Paul Walker
  11. #11 Re: Catalytic converter question?
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  12. #12 Re: Catalytic converter question?
    Nov 2011
    Keswick, Ontario
    Did you notice better response getting rid of the ubend?
  13. #13 Re: Catalytic converter question?
    Apr 2012
    Goderich, Ontario
    Ya, I noticed a little bit more power above about 4k rpm and it also changed my exhaust note. However since we have e-test here I'd recommend buying it without the cheap cat. Buy a good cat. and get that welded in.
    -Paul Walker
  14. #14 Re: Catalytic converter question?
    GT Level Member Shiftingshaddow's Avatar
    KC
    ZZPerformance - ZZP Downpipes #ZZ-GPDP
    get the 2.5" with cat converter. its like 170 and 15 shipping. no probs with mine. or you can get the magnaflow from your parts store (might have to ship) and thats like 225. or maybe rockauto.com
    there's probably a way to clean the stock one out though. google "how to clean catalytic converter"
    dont straight pipe it. i did on a 99gtp and lost fuel economy and the engine light was always on.
    before anyone jumps in to say i'm wrong.....no i'm not. that was the problem. stock cat back on=happy car it was that simple.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  15. #15 Re: Catalytic converter question?
    Apr 2012
    Goderich, Ontario
    That's kinda what I was saying. Buy the ZZP dp. then buy a quality cat. 2.5"inlet/outlet and weld that into the dp. Then just bolt up the dp. These cars don't like cheap cats.
    -Paul Walker
  16. #16 Re: Catalytic converter question?
    Straight pipe plus the defouler trick and poof.. cheap easy and done.
    However..I'd like to hear what that code was.
  17. #17 Re: Catalytic converter question?
    Nov 2008
    Central NJ
    Just as an FYI...If you're doing to work yourself and you do replace the CAT, you should look around to see about scrapping your old CAT. I've seen CATs sell for over $100 on ebay. At least you can make some money back so the investment in the new parts won't hit the wallet too hard.
    I wish I would have known this before I brought my old CAT to a scrap yard and got a whopping $7.50 for it.
  18. #18 Re: Catalytic converter question?
    Apr 2012
    Goderich, Ontario
    I have the P0420 code (same as a few others) and we need a cat. here to pass etest. I like the idea of the defouler thing.
    -Paul Walker
  19. #19 Re: Catalytic converter question?
    KC
    it was 3 years ago but i believe it was the p0420 code.
    two mechanics told me that was the problem. one told me before i did it and said it would run like s#$+. he was right.
  20. #20 Re: Catalytic converter question?
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    Just got my sticker today (big fat R cuz P0420, no cat) thinking bout buying the high flow cat from wbody store (I think it was like 40-50$) and getting it welded in. Tossed around the idea about buying a new pipe with cat in but its way more than I'd like to spend. I'm looking for a 100$ fix haha
  1. catalytic converter
    By musicman126 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2013, 12:09 PM
  2. Catalytic Converter Question
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2012, 07:17 PM
  3. 02 Grand Prix quick catalytic converter Question?
    By cmccarty22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2012, 02:17 PM
  4. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  5. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
