Thread: 02 gtp trans to 03 gtp trans?
Results 1 to 5 of 5
  1. #1 02 gtp trans to 03 gtp trans?
    Detroit
    I have the "no OD" situation, and I don't have $1600 for a rebuild, $2000 for a re-manufactured, or $1200 for a clone that will probably result in the same problem, so I'm asking can I find an 03 4t65e-HD for my 02 gtp since GM realized that the 4th gear stripping was a major problem after all those years and finally hardened the 4th gear... any suggestions?
  2. #2 Re: 02 gtp trans to 03 gtp trans?
    Detroit
    Yes, I'm referring to swapping.
  3. #3 Re: 02 gtp trans to 03 gtp trans?
    Not all 03 have the hardened 4th. It won't work anyway since the valve body is different
  4. #4 Re: 02 gtp trans to 03 gtp trans?
    Detroit
    Well... ****. What can I do?
  5. #5 Re: 02 gtp trans to 03 gtp trans?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    you can get a 03 to work in a 02 but you have to repin the connector and use the old 02 range switch there is a link on club gp to show u how to do it and what pins to move it would be smarter to just get a 02 and not have to mess with the wiring on the car and buy a 4th gear hub and replace it while the trans is out
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  1. Replies: 12
    Last Post: 04-15-2013, 11:18 AM
  2. trans q
    By nicksilvergt99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 09:02 PM
  3. Are a 99 and 01 HD trans the same?
    By Andrew_99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-18-2009, 02:22 PM
  4. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
