#1
Dorman parts any good?
GTP Level Member
04-05-2013
I need a lower left control arm for my car and was wondering if Dorman parts are any good and if you guys would buy them for your Grand Prix's? I can get the right and the left control arm for the same price I would pay for just one control arm at Advance Auto Parts.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Gremlins always seem to show up in pairs, or groups of three with our cars...
![th_laugh-lol3](https://www.grandprixforums.com/images/smilies/th_laugh-lol3.gif)
#2
Re: Dorman parts any good?
Dorman is an ok brand, below high grade like a MOOG, but above most house brands. I would use them on a DD that I didn't care about and just wanted to keep running.
#3
GTP Level Member
04-05-2013
Just looked and MOOG is $80 per control arm as where Dorman is $40 per control arm. The parts look the same to me. What do? I don't plan on junking my car anytime soon and plan on doing more modding.
#4
Turbo is the way to go.
04-05-2013
Many people run dormans, they are good quality for the money, I would run them on any car.
![](https://www.grandprixforums.com/image.php?u=8713&type=sigpic&dateline=1312942437&s=c9d38ba3c46cbcaeb1bcbeefab5a6a30)
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#5
GTP Level Member
04-05-2013
![Quote](https://www.grandprixforums.com/images/redfox/misc/quote_icon.png)
Fivefingerdeathpunch
Just from looking at the pictures the parts look identical I think it's one of those cases where people are just paying for the brand name. For example Autozone charges $92 for a front lower control arm as where you can get the same thing on Rock Auto for $40 and I bet that the Duralast brand for $92 is no better than the Dorman... lmao o_O
#6
GTP Level Member
04-05-2013
Also any tips for installing control arms? Anything else I should replace while I'm doing the control arms since I'm going to be in there?
#7
04-05-2013
Not really, its already replacing the ball joint and bushings, but you may break a sway end link if that are really old, you can replace those if needed.
I'd get poly end-links while you are there. But yeah the difference is mostly in the ball joint, moog just uses a better one, but I'd be willing to bet the control arm itself is about the same.
#9
04-06-2013
+1 for Dorman LCA's...I put a pair on my old 4 door and they worked just fine.
#10
Used moogs because I heard of two people who had trouble lining it up because the bolt holes were drille incorrectly. Love my moogs and they are grease able not sure if dormans are
#11
GTP Level Member
04-06-2013
Logan541
They have a grease fitting? That would be something I'd be interested in for the extra money.
#12
04-06-2013
Yeah the moogs have grease fittings on them.
#13
GTP Level Member
04-06-2013
What type of grease would I buy for greasing the LCA?
#14
I live here.
04-06-2013
You can buy tubes of lithium grease for a grease gun, that's what I use. It's a little pricey but works good.
2002 Grand Prix GT N/A 127k - Same as 06 Plus: Trans Cooler, DIY Aux Input, LED lighting, Suspension Upgrades, Tint, Retrofits. Sold.
#15
04-06-2013
Stock ball joints don't have grease fittings and last well over 100k miles, they are not a common failure point on our cars so it really doesnt matter.
GTP Level Member
04-06-2013
OK so dormans seem to be my best bet
how easy are strut end links to do? What were you guys talking about with the poly mounts? Dormans will ride and feel the same right?
#17
I live here.
04-06-2013
Sway bar links are very easy to do. The hardest part will be getting rusty old ones off, which penetrating oil and an impact gun will help a lot. I recommend using moog links.
#18
GTP Level Member
04-06-2013
Are there any write ups on how to do these?
#19
I live here.
#20
A word of advice I would start getting oil on those bolts now and just every few days do it until you are ready to remove as far as the grease fittings not going to argue with fivefingers because I do respect his knowledge but what I am taking into consideration dormans are not stock GM I don't know if they are made in china or of a lower grade steel or what have you. Granted if I could have gottem my arms direct from GM I would not have cared about the fittings but they wanted too much so I went with moog, and fingers if you tell me dormans are made by GM I will scream lol hate to thing I wasted that much money
