Thread: Replaced temp sensor, now temp gauge stays pegged high...
Results 1 to 12 of 12
  1. #1 Replaced temp sensor, now temp gauge stays pegged high...
    Aug 2012
    Prestonsburg, KY
    Hi. Working on my 22 yr old son's 2001 Grand Prix GT (3.8l motor) again.
    Started stalling when it gets to normal operating temperature, loss of power.
    He works at Advance Auto so they threw it on the comp which told them
    that the temp sensor was bad.
    So we replaced the sensor, thermostat and top radiator hose. (gonna
    replace the bottom one this week, looks like its trying to collapse a
    little bit when you rev the motor up).
    So we get it all back together and he starts it up. Takes off, no problem
    there. However, both fans are turning all the time and the temp gauge
    shows max high temp.
    Since then, one of his friends told him that he needed to "bleed" the system
    using the little screw on top of the thermostat housing, that a bubble of
    air there was causing the problem.
    Not had a chance to try it yet, is it as simple as that? Sounds too easy.
    Thanks everyone.
  2. #2 Re: Replaced temp sensor, now temp gauge stays pegged high...
    St. Louis
    Yep. Since you replaced the thermostat and top hose you introduced a bunch of air into the system. Get it up to temp and crack that bleeder screw open until you get a STEADY stream of coolant from it. Yes, it will leak all over the intake. That's fine. You will notice that it will spit air/coolant for a while. I usually crack it and let it bleed a bit, then shut it and repeat this several times so I don't flood the LIM with coolant.
    Search for "cooalnt bleeding procedure" on here as this is a common issue with these motors.
  3. #3 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Cambridge, Ontario Canada
    I find these cars suck a bit for bleeding the air out, it could take a bit for sure.
    2005 E55 - stock
  4. #4 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Aug 2012
    Tukwila, Washington, United States
    its pretty easy to bleed.
    turn car on.
    wait for fans to turn on.
    then unscrew a little with a flat head the screw on the tstat housing.
    it will start pissing. then close it.
    u r done.
    Grand Prix gt 1999 v6 3.8L coupe.
  5. #5 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Aug 2012
    Prestonsburg, KY
    Okay, we bled the system, replaced the bottom radiator hose, and replaced the
    temp sensor with a new one (Advance claimed the first new one was defective).
    So we did all that, and it's still doing the same thing.
    The computer at Advance is still throwing a bad temp sensor code. The people
    at Advance are claiming its the --> 2nd <-- temp sensor that's bad, not the
    first one under the thermostat?
    Is there a second one somewhere on these cars?
    Thanks!
  6. #6 Re: Replaced temp sensor, now temp gauge stays pegged high...
    St. Louis
    Umm, no. Not that I'm aware of. There is an intake air temp sensor and a coolant temp sensor. That's all I'm aware of. Did you replace the lower hose and temp sensor and THEN bleed the system, or did you do it in the order you listed?
    I'd start checking the wiring to the temp sensor at this point. Might be bad somewhere in the harness or at the clip. Might be time to scan it and see what the temp sensor is actually telling the PCM.
  7. #7 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Florida
    Theres no 2nd coolant temp sensor.
    I just replaced my bad coolant temp sensor with an Advance auto unit they had in stock. Did the exact same thing. Returned it and went to GM and got an OEM sensor, installed it and bam, no more problems.
    Also, make sure that the sensor is plugged in properly, both to the sensor, and to the main harness.
  8. #8 Re: Replaced temp sensor, now temp gauge stays pegged high...
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Get a different brand sensor
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #9 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Aug 2012
    Prestonsburg, KY
    Yeah, we're going to - right now, with the 2nd sensor from Advance, the fans have stopped
    running all the time, but the temp gauge still stays maxed out when you turn the key on.
    Local GM dealer didn't have one in stock, so we had to order it - should be here Monday.
    I'll post the results once we get it in.
    Thanks everyone.
  10. #10 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Dec 2012
    Where 4T65E's were born
    I've always heard that there are 2 engine/coolant temperature sensors. My friend's Monte Carlo's temp sensor is pretty goofy going to all the way hot to all the way cold all the time, and the fans never kick on and the fuel injection system doesn't make it rich assuming its cold making it run bad. Get a scan tool and use it to red the temp there to make sure the gauge isn't at fault.
    Sold.
  11. #11 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Aug 2012
    Prestonsburg, KY
    Good news. We got the GM OEM temp sensor in yesterday and put it in. Fixed everything.
    So the Advance model, whatever it was, was the problem after all.
    Everything is working fine now, fans are coming on/off, temp gauge is reading correctly,
    and all that.
    The GM model was $30 vs $20 for the Advance, but heck, it works.
    Thanks everyone for all the usual sage advice and help!
  12. #12 Re: Replaced temp sensor, now temp gauge stays pegged high...
    Yoga city
    simialar issue on my buddies 05 monte carlo, gauge was pegged. We changed the sesnor and it didnt solve it, ended up being a corroded wire.
  1. 99 GT temp gauge runs high
    By Harley79 in forum General Tech Discussion
    Last Post: 02-08-2013, 04:44 PM
  2. Replaced coolant temp sensor and....
    By NerdPower in forum General Grand Prix Discussion
    Last Post: 04-23-2012, 04:38 PM
  3. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  4. temp gauge pegged
    By PatriotGT in forum General Tech Discussion
    Last Post: 08-29-2010, 04:10 PM
