Thread: 98 GT How to remove Coolant Reservoir?
Results 1 to 6 of 6
  1. #1 98 GT How to remove Coolant Reservoir?
    Mar 2013
    Tempe, AZ
    I found a small crack in my coolant reservoir bottle. I'm going to get one Wednesday and need help on how to remove the bottle. From what I see, I need to remove the support bar, move the intake and box, and I'm assuming its mounted down on the platform that holds it up. Any help would be greatly appreciated!
  2. #2 Re: 98 GT How to remove Coolant Reservoir?
    Yeah thats pretty much it. Try to get one out of a 99+ car as a replacement.
  3. #3 Re: 98 GT How to remove Coolant Reservoir?
    Mar 2013
    Tempe, AZ
    Why so?
  4. #4 Re: 98 GT How to remove Coolant Reservoir?
    It is considered a better setup. The 97/98 bottle has a 4 foot hose that connects it to the radiator, in the 4 feet it passes through both motor mounts (where it appears to be crushed shut) does a few bends, etc etc.
    The newer bottle is closer to the radiator, shorter hose with no obstructions...it's viewed as better.
  5. #5 Re: 98 GT How to remove Coolant Reservoir?
    Aug 2012
    Tukwila, Washington, United States
    yes the 98 bottle is on the driver side by the radiator.
    i think u need the air box out so you can replace the bottle.
    id say dont buy a new one. you can duck tape
    or go to the junk yard
    Grand Prix gt 1999 v6 3.8L coupe.
  6. #6 Re: 98 GT How to remove Coolant Reservoir?
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    You got the idea just expoy the thing also changing to to 99 and up puts the bottle in a bad place to work on the eng belts and leaves less room to check the power steering level, some people that had changed went back to the 98 set up because of the hassel.
  1. Coolant reservoir
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2013, 07:41 AM
  2. Small air space in coolant reservoir
    By Coldwaves in forum General Tech Discussion
    Last Post: 01-15-2013, 12:17 PM
  3. Coolant reservoir
    By TheManInBlack in forum Shops and Community Heroes
    Last Post: 12-31-2011, 02:50 PM
  4. Gray liquid in coolant reservoir on 97 gtp
    By SteveCZ28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:47 PM
  5. Coolant Reservoir Tube?
    By Pagss in forum General Tech Discussion
    Last Post: 10-19-2010, 01:49 PM
