Thread: Bad struts?
Results 1 to 6 of 6
  1. #1 Bad struts?
    Aug 2012
    Tukwila, Washington, United States
    Recently my car making noise on the high way of shaking sound.
    When on bumps it sounds like boom.
    Anyway it sounds like its coming from the front driver side.
    The problem is that i have rust and really scared to do anything there.
    How can i know for sure what it is?
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: Bad struts?
    Jack the car up and look under there while moving the tire and see if anything is loose.
  3. #3 Re: Bad struts?
    SE Level Member younger5th's Avatar
    Apr 2013
    Connecticut, US
    My car has an issue where when I turn to the right, it vibrates. The faster I'm going the harder the vibration. While searching for a solution I've read some people with your issue and one suggestion was worn engine mounts.
  4. #4 Re: Bad struts?
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by younger5th View Post
    It sounds like u have a bad CV half shaft. If ur turning right then it would be ur passenger side CV shaft. Also could be a bearing as well
    To check bearings Jack car up and grab the wheel at 12 and 6 o'clock and see if it has any play.
    On the CV shafts check to see if their leaking grease or if the boots are ripped
  5. #5 Re: Bad struts?
    Apr 2013
    Connecticut, US
    I found that same diagnoses a lot of places. Guess that's the most common up there with struts. I know I might have a bearing issue, but I doubt think it's bad enough to cause vibration. I need to repair a couple things before selling the car...this problem being one; should I replace both half shafts or just the drivers side? (apologies for semi-hijacking the thread >_< )
  6. #6 Re: Bad struts?
    Jun 2012
    Well I did both of mine. Vest guess would be take wheels off and look the shafts over really well. And buy Napa shafts they tend to be best oe replacements
  1. Struts
    By 2007GrandPrixGT in forum Brakes/Suspension/Chassis
    Last Post: 01-04-2013, 01:53 PM
  2. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
  3. How to tell if struts are bad?
    By GTLGDP in forum General Tech Discussion
    Last Post: 05-05-2012, 11:23 AM
