Thread: Multiple EGR Codes
Results 1 to 15 of 15
  1. #1 Multiple EGR Codes
    Mar 2013
    Kansas
    Wow forget the transmission issues I was having! My 99 Grand Prix GT started surging at highway speeds mainly when it was going up a hill. I hooked my code reader up and come up with multiple EGR codes. They include P1404, P0405 (twice) and P0404. Looking them up to try and find possible solutions has almost been impossible. Any ideas?
    99 Pontiac Grand Prix GT 3.8 N/A K&N CAI E3's
    "If you can't drive it like you stole it...sell it!"
  2. #2 Re: Multiple EGR Codes
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0404 Exhaust Gas Recirculation Circuit Range/Performance - DTC Code
    Read those, should give you an idea of what you need to do to fix the issue.
  3. #3 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    Thanks. It's all a little above my head but, unless I pay someone money I don't have, I gotta figure it out and they are detailed enough I just might be able to.
  4. #4 Re: Multiple EGR Codes
    all them codes lead to a bad egr valve, or bad wires to the valve. id start there.
  5. #5 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    I'm gonna check the wires first. I replaced the egr valve little over a year ago when I got the first P1404 code. Reset the service engine light but it came back. It went away when the weather warmed up but came back when winter hit again. When the car started surging I checked and came up with the other codes.
  6. #6 Re: Multiple EGR Codes
    this link says that code is for a stuck egr, the wires may be bad if you changed the egr already.
    DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
    Circuit Description
    This diagnostic tests for an EGR valve that is stuck open. The PCM determines that the EGR valve is stuck open if the actual EGR position and the learned closed EGR position vary by more than a predetermined value. The PCM tests for a stuck valve when the desired EGR position is at 0%. The PCM commands the EGR valve to 100% during certain driving conditions in order to clear a possible restriction from the EGR valve if the PCM determines that the valve is stuck open. The PCM retests for a stuck valve when the desired EGR position returns to 0%. A failure timer increments if the stuck EGR valve condition is still present. This DTC sets when the timer reaches a predetermined value.
    Conditions for Running the DTC
  7. #7 Re: Multiple EGR Codes
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I know this is a stretch, but did you put a new EGR in or a used one? I had the same code on my GP and replaced it with a junkyard part. Lasted about a week before giving the same code again. Picked up another junkyard one, and it seemed to be doing better. Still cheaper to buy two than to buy a new one.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  8. #8 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    Replaced with a new one through an online parts store. Taking it to a mechanic soon to get looked at since my code reader doesn't have live readings.
  9. #9 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    Ok so just got it back from the mechanic and everything checked out good. No voltage issues. EGR works. Nothing blocking the valve. The machanic recommended getting the update from the dealership and that could possibly clear all the egr codes.
  10. #10 Re: Multiple EGR Codes
    Jan 2013
    michigan
    what is this update you are talking about?
  11. #11 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    Apparently it's just an update in the programming. I was told about it over a year ago when I first had the P1404 code appear.
  12. #12 Re: Multiple EGR Codes
    Jan 2013
    michigan
    hmm interesting i also had the 1404 code come up a few days ago after it went away for a while. but i'm probably just going to deletemy egr since there is no emissions test in mi
  13. #13 Re: Multiple EGR Codes
    dealer pcm re flash, installs the latest up grades/programming for the engine. this only works for a stock pcm. if you let them do this to a tuned pcm, say bye bye to said tune because they will make it stock again.
    had to have it done on my gmc truck.
  14. #14 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    I'm completely stock, as far as I know, so I don't need to worry about that.
  15. #15 Re: Multiple EGR Codes
    Mar 2013
    Kansas
    There's no emissions here in ks either but I'm not able to play around until I get a different daily driver.
  1. Multiple Codes - Help Needed. : Images attached
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2013, 04:46 PM
  2. error codes multiple
    By izup69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2011, 03:35 PM
  3. Multiple Codes!!!! Need Help!
    By roundbox52 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2010, 08:01 PM
  4. Another idle surge/misfire problem with multiple codes
    By Justinzoso in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2010, 11:43 AM
  5. Multiple codes
    By silverstreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 12:35 AM
