Thread: Car wont star :/
Results 1 to 20 of 29
  1. #1 Car wont star :/
    Aug 2012
    Tukwila, Washington, United States
    I went to target parked my car.
    Everything was normal.
    Trying to turn it on. But the car turns off a second after it starts.
    I tried to press on the gas and it died even when pressing the gas.
    Plz help. Im stuck here.
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: Car wont star :/
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    My GTP did the same thing a couple weeks ago... Ended up being relay #15. Good luck!
  3. #3 Re: Car wont star :/
    Aug 2012
    What is this where is this?
  4. #4 Re: Car wont star :/
    Nov 2012
    Madison
  5. #5 Re: Car wont star :/
    Aug 2012
    Tnx ill try it. How do i get it now. Im stuck at a store 40 mins from home. Dammit.
  6. #6 Re: Car wont star :/
    Nov 2012
    Frankenmuth, MI
    You can bypass it. The picture in the link spazzz posted shows how.
  7. #7 Re: Car wont star :/
    Aug 2012
    Thats weird. I dont have any relay there.
    Any chance someone messed with my car or maybe cz its a gt
  8. #8 Re: Car wont star :/
    Thats GTP only for 97-00.
    Try unplugging the MAF sensor and see it runs.
  9. #9 Re: Car wont star :/
    id check for fuel at the rail. no gas up there its a fuel pump problem for sure, or a bad fuse.
  10. #10 Re: Car wont star :/
    Aug 2012
    I tried to pull the map sensor. It turned on but very rough so i turned off after 2 seconds.
    Whats going on there
  11. #11 Re: Car wont star :/
    The map or the MAF, the maf is ontop of the throttle body.
    I would say if it ran, then that might be the issue, because before it wouldnt run for more than a second.
  12. #12 Re: Car wont star :/
    Aug 2012
    Ok i pulled the maf out. The car runs good.
    What should i do now.?
    Btw rpm go up and down a bit.
    Can i drive it? Or something will happen?
  13. #13 Re: Car wont star :/
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    dont pull it out, just unplug it
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  14. #14 Re: Car wont star :/
    Aug 2012
    Quote Originally Posted by Madness View Post
    Thats what i did. Sorry.
    Anyway. Can i drive it?
  15. #15 Re: Car wont star :/
    Quote Originally Posted by raverockstar View Post
    If it runs good with it unplugged, just drive it like that to get it home, don't beat on it or get up to speed really fast, just go easy on it going home. Likely you will need a new MAF sensor.
  16. #16 Re: Car wont star :/
    Aug 2012
    Can something happen?
    I have road side assistance. I prefer it towed than having engine problem
  17. #17 Re: Car wont star :/
    Nothing can happen really, the car uses the MAF sensor to determine fuel and air flow into the motor, when its unplugged the computer already has a whole file full of numbers to go off of incase the MAF sensor were to ever fail. Its not completely correct on what really going on, but it has enough data to run the car just fine.
  18. #18 Re: Car wont star :/
    Aug 2012
    Ok. Thank you. Ill try to get home.
  19. #19 Re: Car wont star :/
    Aug 2012
    Air intake sounds bad. Like its sucking air. And i got a check engine light.
    Thats the code
  20. #20 Re: Car wont star :/
    A code will come up because the sensor is unplugged.
    Does the car still run okay though?
  1. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  2. On star Computer
    By klj5022 in forum General Tech Discussion
    Last Post: 04-05-2011, 09:07 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. 2000 GTP wont star ??
    By handymontana in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2010, 10:59 AM
