Thread: Pulled ABS Fuse-Stiffer Steering
Results 1 to 9 of 9
  1. #1 Pulled ABS Fuse-Stiffer Steering
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    I have a bad wheel speed sensor in my right front wheel that causes my ABS to act up at low speeds. I dont have the time or cash to get this fixed right now so i pulled the ABS fuse (#23) and problem solved, i can deal with the TC,ABS, and Brake lights being on. I found that pulling that fuse makes my steering stiffer, its not as stiff as when my PS pump went, but there is a difference.
    I can still hear the pump so I know its still functioning, but is there a component to the power steering system that shuts down when the ABS is out? I know that driving without any PS can ruin the steering rack, but will this cause any harm?
    Thanks
    2004 GT2
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  2. #2 Re: Pulled ABS Fuse-Stiffer Steering
    Pennsylvania
    Maybe that's the same fuse for your magnasteer? Now you turn like a base model.
  3. #3 Re: Pulled ABS Fuse-Stiffer Steering
    some how the abs and magna steering are tied together, sometimes if the abs light comes on the steering can get stiff. so pulling the fuse could cause it. put the fuse back, if the steering is normal you know thats what caused it.
  4. #4 Re: Pulled ABS Fuse-Stiffer Steering
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    EDIT: Sorry missed something.
  5. #5 Re: Pulled ABS Fuse-Stiffer Steering
    Sep 2012
    Bangor, ME
    Scotty: replacing the fuse did bring back the magnasteer.
    I was not aware Magnasteer was an option, thought it was just GM's "brand name" for power steering. I actually like this stiffer steering, can anyone give me a good reason why I shouldnt run without Magnasteer? I know running without PS can ruin the rack, but will going without Magsteer hurt anything?
    GOD BLESS...
  6. #6 Re: Pulled ABS Fuse-Stiffer Steering
    the manga steer is power assist, electrical. no idea if its bad for the rack or not for it to not be powered.
    it makes the steering easier or harder depending on your speed.
  7. #7 Re: Pulled ABS Fuse-Stiffer Steering
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    My car has been like that for at least a year (that's when I got it). my abs light has always been on and my steering so going without magnasteer will be fine.
  8. #8 Re: Pulled ABS Fuse-Stiffer Steering
    Yoga city
    would thik if you had those lights, it should disable the magna steer, i know as soon my lights come on it goes.
  9. #9 Re: Pulled ABS Fuse-Stiffer Steering
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Your EBCM Controls the function for your magnasteer actuator in the steering rack. Bad ebcm or no fuse = no magnasteer
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
  2. Pulled Over
    By fri3dchick3n in forum The Rant Forum
    Last Post: 06-17-2012, 02:10 AM
  3. Just got pulled over
    By shawnschuldt in forum The Rant Forum
    Last Post: 07-09-2011, 04:43 AM
  4. Stiffer springs
    By njbrain in forum Brakes/Suspension/Chassis
    Last Post: 11-25-2008, 07:46 PM
  5. Stiffer Suspension and aftermarket feel HELP
    By rczzv in forum General Tech Discussion
    Last Post: 05-13-2008, 11:50 AM
