Thread: 2000 pontiac grand prix gt will not start.
Results 1 to 13 of 13
  1. #1 2000 pontiac grand prix gt will not start.
    Aug 2012
    Nova Scotia
    Its quite cold out and my car has sat for 2 months in the cold and the gas is from november. And I just put a pcm in from my 99 into this as I swapped its engine into my 2000. What do you think is wrong? It will crank slowly even when you boost the battery but just will not start. It crank slow. I have another battery that is charged and has been kept inside. Should I just use that battery? Please someone help. I'm ready to give up..
  2. #2 Re: 2000 pontiac grand prix gt will not start.
    St. Louis
    Slow crank and cold. Hmm, sounds like a dead/dying battery that cannot supply the proper amount of CCA's to spin it over. I'd slap a new good battery in it and make sure all connections are clean and tight at the battery, and check the ground at the trans. bellhousing since you just swapped motors. Might have missed one.
  3. #3 Re: 2000 pontiac grand prix gt will not start.
    Once you swap the battery and it cranks fast. You may need to relearn the key.
  4. #4 Re: 2000 pontiac grand prix gt will not start.
    Aug 2012
    Nova Scotia
    Quote Originally Posted by FordMan77 View Post
    Thanks man! I already have a good battery sitting inside in the warmth! And were exactly is that groud at? But ill let you knohrough personal message and see how it goes thanks!
  5. #5 Re: 2000 pontiac grand prix gt will not start.
    Aug 2012
    Nova Scotia
    Alright thanks bill! How do you exactly re-learn the key?
  6. #6 Re: 2000 pontiac grand prix gt will not start.
    St. Louis
    The grounds should be on one of the bolts that are on the transmission. If you pop the hood and face the motor, look down under the exhaust crossover where the trans. meets the engine block and follow it down. Somewhere down there is a stud that should have some black ground cables attached to it. I can't find a pic so if you really need it I can take a pic of the grounds my 00 GT and put it up here for you.
  7. #7 Re: 2000 pontiac grand prix gt will not start.
    Aug 2012
    Nova Scotia
    I think i might know where you mean. But yes please take a pic for me so i know exactly what you mean! Thanks!
  8. #8 Re: 2000 pontiac grand prix gt will not start.
    St. Louis
    I'll get a pic when I get home from work today for you.
  9. #9 Re: 2000 pontiac grand prix gt will not start.
    St. Louis
    Below is the pic of the location of the engine grounds. Circled in yellow. Just click on the pic to enlarge it.
  10. #10 Re: 2000 pontiac grand prix gt will not start.
    Aug 2012
    Nova Scotia
    thanks man! appreciate it!
  11. #11 Re: 2000 pontiac grand prix gt will not start.
    Aug 2012
    Nova Scotia
    so about the old gas? the gas has been in there since november and its now almost april... would the gas still be good or?
  12. #12 Re: 2000 pontiac grand prix gt will not start.
    St. Louis
    Gas should still be good. My 74 MG sits in storage for about 7-8 months a year and it fires right up with the old gas in it. If in doubt just shove a bottle of Heet in it and then some fresh gas. Should take any moisture out of it. The lower the tank when it sits that long, the more moisture it can accumulate.
  13. #13 Re: 2000 pontiac grand prix gt will not start.
    Mar 2013
    Kansas
    I don't know much about the OBD 2 or what will interchange with what but isn't the pcm programmed with the VIN in it? And if so couldn't that be the issue if nothing else hasn't worked?
    99 Pontiac Grand Prix GT 3.8 N/A K&N CAI E3's
    "If you can't drive it like you stole it...sell it!"
  1. 2000 pontiac grand prix gt sedan bronzemist color 2000 obo
    By wavedout33 in forum For Sale - Vehicles
    Last Post: 02-09-2013, 07:25 AM
  2. 2000 grand prix gt still won't start
    By Egibb12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2013, 01:05 PM
  3. 2000 grand prix - no start
    By hflier in forum General Grand Prix Discussion
    Last Post: 12-17-2012, 12:32 PM
  4. 2000 Grand Prix won't start, help please
    By hockeyrulez in forum General Tech Discussion
    Last Post: 03-22-2012, 04:08 PM
  5. 2000 Grand Prix GT 3.8l V6 No start
    By Flava601 in forum General Tech Discussion
    Last Post: 08-26-2010, 01:27 AM
