Thread: Oh great... Not another pully size thread
Results 1 to 5 of 5
  1. #1 Oh great... Not another pully size thread
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Normally I never would post a thread like this but I seriously am not sure what pully size to get for my e85 swap even after some serious searching.... Got a bit of an interisting setup. 01 GT, ZZP SSM90 kit, GEN V Blower (On a ssm90 LIM this is the interisting bit), ER Rockers, PLOG, 3" DP, Northstar TB, LQ4 Maf, Gtp 2 bar map sensor swap, 180 tstat, CAI, 60LB siemens deka 4 injectors, ZZP rails, Alternator rewire.....
    Planning on doing a vs cam and headers later this summer but for now I was just switching to e85 because its basically a free mod at this point. Im currently running a 3.6" pully 11.5 AFR, and 16* of timing (Didnt gain any power going above 16* of timing on the dyno at any boost level).... No kr at any time except my occasionally lean tip in (havent got around to fixing that yet) and the usual bit of kr during shifts.
    Got a casper fuel pump rewire in the mail.... already gained about a volt from the alt rewire.... was planning on dropping to the smallest ssm90 3.4 pully that i own / is physically possible with a ssm90 pully initially.... What im wondering is what pully I should get for when I switch to a gtp belt tensioner setup. (As soon as someone sells me one). I was thinking a 3.3 pully or maybe even a 3.2?
    Any input apreciated.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: Oh great... Not another pully size thread
    Apr 2011
    Vassar, Mi
    If I was you I would go for atleast the 3.2. It is hard to say though with top swap compression and stock cam. On my setup on 93 I had a 3.4" w/ occasional 1-2* KR when running really hard (ei. WOT 3rd pulls) on stock timing. Changing nothing else but going to E85 I dropped to a 3.1" and put the timing up to 21*. 0* KR across the board even on back to back 3rd pulls, made me wish I had went to a 2.9". I only gained .5 psi on my pulley drop though.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: Oh great... Not another pully size thread
    Feb 2008
    If you plan to continue running E85, then you should be able to rock the 3.2 once you get the cam in. If you want to switch back to gasoline, I would suggest you stick with the 3.4.
    With 9.5:1 pistons, and an XP cam, I was switching back and forth between a 3.1 and a 3.2 on my gen3 with gas.
    Sent from my SkyRocket
  4. #4 Re: Oh great... Not another pully size thread
    Nov 2011
    NY
    It's simple, scan for KR, tune, drop... Scan, tune, drop... Etc. lolz, how LOw can you go!
    Take the guessing out of the equation. There's always someone looking for pulleys so you'll get some of your $ back, no biggie!
  5. #5 Re: Oh great... Not another pully size thread
    Apr 2011
    South Dakota
    Im running a 3.6 on my genV with rockers and high compression no problem on 91 octain. No kr when im scanning in hptuners. Im putting my pump rewire in saturday and switching to e85 and my 3.4 pully. Ill let you guys know how it goes.
    I love Decker<3
  1. Pully size and MPG?
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 07-25-2012, 05:35 PM
  2. Thread size help
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-21-2011, 09:11 PM
  3. yes i know another pully size thread
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2011, 09:52 PM
  4. Pully Size ?
    By Beanz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2009, 12:30 AM
  5. pully size? (not the sc pulley)
    By SlowPurpleGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2008, 08:39 PM
