Start by running your wires down the left side your dash.
Have all the wires run behind the carpet thing under the dash. You can remove that by pulling the black clips/pins that hold it on.
Nice and hidden behind the carpet
Continue to run them behind the cubby and under the passenger side carpet also.
Behind the passenger side carpet (partially removed to show you)
Run those wires all the way to the right side of the car to where the fuse box, now youll have to run the wires up to the fuse box from behind it. Can get a bit tricky. Then use the "Add-a-Fuse" thing from any local parts store for the constant and switched 12v sources.
