Thread: 3x A Charm?
Results 1 to 8 of 8
  1. #1 3x A Charm?
    Nov 2012
    Las Vegas
    1997 Pontiac Grand Prix; 159,000 miles.
    Battery 6 months old; new starter.
    Started first time, every time during previous 5 months. Last two days car wouldn't start until 3rd crank. Brought it into AutoZone today to see if maybe the battery wasn't being charged, but they checked it out and the battery, starter, and alternator all checked out. I have noticed that my radio's display does some very weird things, too. I thought about the gas I put in recently at a Flying J, but once started, the car runs great. I found a mechanic who will work on 1997 Grand Prix if I need to get it towed, but any ideas why this is happening all of a sudden? Thanks!
  2. #2 Re: 3x A Charm?
    St. Louis
    Check all your cables for corrosion and tightness. A loose or corrded cable or ground can cause hard starting/wierd electrical things (the radio display). Or it's possible that you have a bad cell in the battery. Did they load test the battery or just check it for charge? A static battery can test out fine, but once you hit the starter the amp draw may be enough that it kills the battery and it can't fire up.
  3. #3 Re: 3x A Charm?
    Nov 2012
    Las Vegas
    I checked for battery corrosion and I re-tightened the battery cables (that happened to me before because car rides so low and the roads in Salt Lake City are so rutted because of the road salt and the snow.) They did a test for a charge and the tester said it may be a loose ground. I haven't a clue where that would be located.
  4. #4 Re: 3x A Charm?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    low fuel pressure maybe? try Turning the key on and let the fuel pump prime without cranking the motor, then repeat that a couple more times then crank it over to see if she fires up.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  5. #5 Re: 3x A Charm?
    Nov 2012
    Las Vegas
    Thanks. I'll give that a try tomorrow a.m.
  6. #6 Re: 3x A Charm?
    St. Louis
    Grounds are located on a stud on the transmission bell housing. If you stand in front of th car and look down the edge of the trans you should see it there. Might want to remove them, clean em up and then make sure they're tight.
  7. #7 Re: 3x A Charm?
    Nov 2012
    Las Vegas
    I tried the fuel pump priming and it worked! What should I look for as the cause and what would I do for repairs? Thanks!
  8. #8 Re: 3x A Charm?
    St. Louis
    Clogged fuel filter would be a cheap place to start, especially if it hasn't been replaced before. Could also check the fuel pressure regulator. Pull the vacuum line off of it (with the car not running) and see if fuel leak out of the line. If so, then replace the regulator. Other than that it could be a weak pump.
  1. Third times a charm BMW vs bone stock gp se
    By bandits grand prix in forum Track Sessions and Kills
    Last Post: 10-17-2011, 10:22 AM
  2. Passed emissions!!! 3rd time was the charm!!
    By jokyfo in forum General Tech Discussion
    Last Post: 12-17-2010, 04:57 PM
