Thread: 180 T stat suggestions ?
Results 1 to 20 of 24
  1. #1 180 T stat suggestions ?
    Feb 2013
    Ohio
    Is a high performance thermostat the better choice ? Thanks.
  2. #2 Re: 180 T stat suggestions ?
    No.
    Worthless without the fan turn on points lowered in the PCM anyways.
  3. #3 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    Do I have to ask 3800 performance to have that added to the PCM ? They don't have a phone # they haven't emailed me back yet.
  4. #4 Re: 180 T stat suggestions ?
    There is no high performance thermostat.
  5. #5 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    I have seen a couple advertised as high performance as high as $37.00.
  6. #6 Re: 180 T stat suggestions ?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Don't buy it.
  7. #7 Re: 180 T stat suggestions ?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    you got stants normal stat or their "superstat" which is about $4 more. Flip a coin and go with it.
    97 Bonneville SE Not so much a 97 anymore
  8. #8 Re: 180 T stat suggestions ?
    SE Level Member schollianmj's Avatar
    Dec 2012
    Virginia
    Why do you think you need it? How modded is your car? you really dont need to worry about that untill your fairly up there in modding.
  9. #9 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    I'm just starting to order parts, I haven't moded anything since my grand national days when I ordered my 87, so I'm a green horn at this. Just got an 02 40 anniversary gtp with 85,000 on it,here's my plan so far catless down pipe, 3.5 pulley, PCM,autolite 104 plugs,transgo shift kit,jmb fender intake,180 stat,smaller v belt, zzp motor mounts,stabilizer links,lower control arms. Any input would greatly be appreciated . Thanks for your time. John
  10. #10 Re: 180 T stat suggestions ?
    skip these parts:
    - shift kit (no need, seriously - the tune will handle stiffening up the shifts)
    - thermostat (100% useless item, i don't care who you are)
    - motor mounts (unless you need them, of course)
    - LCAs and end links are only necessary if yours are junk, as well
    put the money you save on those and put it into something else. like lowering springs.
  11. #11 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    Thanks man I appreciate the info. I have been told my car is factory lowered, it seems to look lower than other grand prix's.
  12. #12 Re: 180 T stat suggestions ?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by JT2002GTP View Post
    Before you get excited make sure the trunk isn't full of dead bodies. Lol
    I went NA when a whore left -$300 in my bank account.
  13. #13 Re: 180 T stat suggestions ?
    Jun 2011
    Factory lowered?
    You mean saggy springs.
  14. #14 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    I have been told my 40 anniversary gtp came from factory already lowered. I don't know for sure if this is true or not, but it does look lower to me than non 40 anniversary cars. Car has 85,000 so I don't think suspension is shot. No bodies in trunk.
  15. #15 Re: 180 T stat suggestions ?
    springs.
    unless the struts are physically longer than the stock ones, they have nothing to do with ride height.
  16. #16 Re: 180 T stat suggestions ?
    No, the 40th Anniversary cars did not come lowered, whoever told you that was wrong. The SLP cars had a GMPP/Koni optioned out suspension that lowered the car a smidge, but not very much at all.
    Sure the tires are the correct size?
  17. #17 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    Ok thanks for the info. How do I find out if my struts are shot ?
  18. #18 Re: 180 T stat suggestions ?
    its how old now?
    Of course the springs can be saggy.
    Mine had 80K or something useless on them and were sagging.
  19. #19 Re: 180 T stat suggestions ?
    It wont be the struts. It will be the springs.
    Take a picture, most on here should be able to tell how its doing.
  20. #20 Re: 180 T stat suggestions ?
    Feb 2013
    Ohio
    So the springs are separate part of strut ?
  1. 160 T-Stat
    By Jcal1120 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2011, 08:39 PM
  2. should i get a 180 or 160 t stat?
    By 98gtp1000 in forum General Tech Discussion
    Last Post: 02-21-2009, 10:15 PM
  3. 180 T-Stat
    By wykabryan in forum General Tech Discussion
    Last Post: 11-17-2008, 03:27 PM
  4. Which t-stat should I get?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 08:49 PM
  5. 180* T-stat
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 10:30 PM
